Anyone replace their licence plate lamps with LED's? - Page 2
Results 16 to 30 of 31
Like Tree5Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, Anyone replace their licence plate lamps with LED's? in Past Cadillac Vehicle Discussion; licence plate lamps with LED's...
  1. #16
    REVELATION13 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac DTS
    May 2011
    40
    108
    Thumbs upRe: Anyone replace their licence plate lamps with LED's?
  2. #17
    Phatalac is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS LUX III
    Oct 2011
    27
    130
    well that sold me, they dont seem that bright tho or is it just the way the picture is taken?
  3. #18
    jsmith392003 is offline Cadillac Owners Member
    Automobile(s): jsmith05403@gmail.com
    Jan 2012
    vermont
    53
    6
    I replaced mine in my 2008 with these from E-Bay.
    LED WHITE 2X LICENSE PLATE TAG LIGHT BULB T10 158 161 168 194 2825
    I also replaced the bulbs in the doors with LED's which are2x 41mm FESTOON DOME MAP WHITE 16-SMD LED BULBS 569 578
    Both worked well and make the car look alot better.
  5. #19
    _ike_ is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS Luxury III
    Feb 2011
    184
    What new cadillacs have the updated lights for the license plate? Are you sure it is LED and not CCFL as most manufacturers are using?
  6. #20
    cadillac_guy21's Avatar
    cadillac_guy21 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac DTS, 1966 Cadillac Sedan DeVille
    Jul 2012
    Savannah , Ga
    197
    Bump
    I jus changed mine this weekend and took the car out after washing n waxing... A lot of people were breaking their necks , I even had another dts that was tailing me try to pull up next to me while I was driving to look at the car , we both had same color almost except when you get close to mine you see it's not completely black it's different ,bottom line switching my bulbs was a good investment,
  7. #21
    RubirosaGGatsby is offline Cadillac Owners Member
    Automobile(s): DTS
    Jan 2013
    42
    I just did mine with the LED's from the auction link posted on the previous page. I used a set of needle nosed pliers just to loosen the bolt that held the light's housing in place, but it was all doable by hand from there; only took about ten minutes. Here's a comparison with the LED on the left, the factory light on the right:
    Gomaz likes this.
  8. #22
    BlueAngel#07's Avatar
    BlueAngel#07 is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 DTS PERFORMANCE
    Feb 2013
    Minnesota
    1,082
    Yeah, I did. Like the guy earlier, I got mine from super bright LEDs . They just barely fit, got the brightest ones that would go in $6.95 each but I really like the result.
  9. #23
    Eddie39's Avatar
    Eddie39 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS LUX II 65k - Once owned 1998 Deville & 2002 Deville
    Jun 2011
    South Carolina Lowcountry
    178
    Quote Originally Posted by tightwad View Post
    yes, I did this a few weeks ago on my 2007. I bought mine from the website below. They have a lot of tech info and a bulb finder by vehicle. I also did the trunk light and the door courtesy lights. You can find other posts on how to do the door lights. It's a little tricky. The license bulb holders have some reinforcing ribs inside. I had to grind mine out with a dremel tool. Not a big deal. They work great, but next time, I may get a slightly brighter bulb. I bought the $5.95 bulbs. Going up a buck or two gets you more selection on output. But the pure white color is way cool.
    http://www.superbrightleds.com/
    Can you tell me how you get to the bulb in the door courtesy lights?
  10. #24
    HASSAN4477 is offline Cadillac Owners Member
    Automobile(s): 06 DTS PERFORMANCE
    Oct 2012
    43
    Pop the clear lens off with a small flat screw driver
  11. #25
    Feb 2013
    Minnesota
    1,082
    Quote Originally Posted by BlueAngel#07
    Attachment 104568
    Looks like ....
  12. #26
    peryan is offline Cadillac Owners Member
    Automobile(s): 2007 Lux1 DTS. Uncle bought new. Meticulously maintained.
    Nov 2013
    Illinois
    53
    I replaced my 2007 plate lights with LEDs from an internet site. They fit perfectly and look 100% better than the old incandescent bulbs. Just google it...
  13. #27
    Nov 2013
    Illinois
    53
    I ordered mine from ijdmtoy.com. They fit my 07 dts perfectly. About $18 with shipping.
  14. #28
    Atavar is offline Cadillac Owners Fanatic
    Aug 2013
    ND
    61
    211
    Both of the pictures in this post illustrate exactly why I don't like replacing incandescent bulbs with LED's. They just do not illuminate as well or as evenly. Laws of conservation apply, power in (watts) equals power out (lumens).
    I hate that it is getting impossible to find a quality flashlight with incandescent bulbs any more. To get the same power and light quality as a $10 incandescent maglight you need to get an $80 LED flashlight, and then it draws so much power it doesn't have any more run time than the incandescent bulb did. As a volunteer firefighter I have learned that when it gets down to it LED's don't come close to performing as well as incandescent. If you throw in dollar for dollar the disparity is worse.
  15. #29
    TopherS is offline Cadillac Owners Fanatic
    Automobile(s): '08 DTS LuxIII (97K mi.), '06 SRX V6-AWD (58K mi.)
    Sep 2011
    Portland, OR
    45
    309
    I just replaced mine with LED bulbs I got at Batteries Plus (they now sell light bulbs). They had 2 types of LED bulbs there that are replacements for 194 bulbs (both packages say that they replace 194 bulbs). The first type was a base with LEDs that face straight out (looks cut off) and the other type had a multi-directional set-up coming out of the base (all told; a little larger than the 194 bulb it replaces). I got the multi-directional bulbs. They BARELY fit ... they go about 99.9% of the way in and rub that last .1% ... but I did not feel that I had to damage anything to get it installed fully. They look good ... I'm happy with the result.
    They were $6.99 each, so $13.98 out-the-door ... no shipping costs/no waiting ... and they said that if it did not work, they'd take them back.
  16. #30
    Nov 2013
    Illinois
    53
    With the tail, 3rd brake and back-up lights all being LED, it's only logical that the license plate lamps look the same from a Kelvin level. The look at night is much more uniform with LED license bulbs. I also think that they complete the look of a newer, more modern DTS by keeping the illumination of all rear end uniform. I am now moving to the interior lighting. I have very "cool" LED's as main lighting, but the ash tray, door and vanity bulbs are "warm" incandescent. Why?
  17. Remove Advertisements
