Tire Pressure Monitor Problems
Results 1 to 6 of 6
Cadillac DTS Forum - 2006 through 2012 Discussion, Tire Pressure Monitor Problems in Past Cadillac Vehicle Discussion; I have had the "service tire monitor system" message for a couple months now but I can't bring myself to ...
    richardson42 is offline Cadillac Owners Member
    Automobile(s): 2000 DTS
    Mar 2008
    State College, PA
    17
    I have had the "service tire monitor system" message for a couple months now but I can't bring myself to pay 200 dollars for a valve stem! Is there any other option than just purchasing a new one and having it installed? That tire also loses pressure at about 5 pounds a week.
    Thanks
    HartfordGuy's Avatar
    HartfordGuy is offline Cadillac Owners Enthusiast
    Automobile(s): 1968 Eldorado
    Oct 2009
    Hartford, CT
    50
    785
    Re: Tire Pressure Monitor Problems
    Go on ebay. You can buy new sensors from $19 to $60 depending on the year and model. Then bring the sensor to a tire shop when you get tired of loosing 5lbs per week.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    My local Discount Tire Company sells them for about 40/50 bucks.
    If you do business with them... installation is free..
    Otherwise is is just a few bucks to have it installed.
    Texas Jim
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    From what I can figure out there are 2 makers schrader and somebody else of course a number of brands and more than one color delco green schrader red standerd black etc I have read that they may not be compatible with the other 3 sensors but then It just might be the installers. I dont know how hard it is to replace,maybe some one who has replaced one can help out.I think schrader makes the delco sensor for the 06 dts but I dont know about a 2000 dts.Mike
    tightwad is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS, 1977 Seville
    Nov 2011
    66
    104
    I searched for alternatives on the internet and found an aftermarket brand - Oro-tek. Less than $30 each. I bought four because one of my factory sensors went out. I assumed a bad battery and figured the others wouldn't be far behind. I had Discount Tire install them when I bought new tires. Working great after 6 months and very accurate.
    stormnn's Avatar
    stormnn is offline Cadillac Owners Fanatic
    Automobile(s): 06 Cadillac DTS
    Sep 2008
    Bowmanville Ont. Leesburg Fl.
    73
    278
    The leaking tire is probably rim corrosion. Clean the rim & re-install the tire with a sealant, that will stabilize the pressures & I bet the service tire monitor system warnings will go away. Worked for me.
    Norm
  9. Remove Advertisements
