Oil leak vs. Seepage issue
Results 1 to 5 of 5
Cadillac DTS Forum - 2006 through 2012 Discussion, Oil leak vs. Seepage issue in Past Cadillac Vehicle Discussion; So most if us that have bought cadillacs have run into the oil leak vs, seepage issue. What do you ...
    DS1784DS is offline Cadillac Owners Member
    Automobile(s): 2007DTS
    May 2011
    WARREN, MICHIGAN
    60
    24
    So most if us that have bought cadillacs have run into the oil leak vs, seepage issue. What do you think? I think if oil is coming from the pan to block seal its leaking. The seal or gasket is there to prevent the oil from exiting the engine. When oil starts to come out the gasket/seal, its leaking. I REALLY DON'T THINK THE OIL HAS TO RUNNING ON THE GROUND TO VERIFY THE LEAK. My local caddy dealer told me its just seepage on my 2007 dts with 72,000 on the clock. Now i own an auto repair shop and i am asc certified mechanic and have been for 35 years. I really don't understand why they just don't repair this. Yes its a very long time consuming job, but it is under warranty for another 28,000 miles and 5 more months. Seems like the dealer would take care of this to preserve its image and that of the brand. This is my fifth cadlillac by the way. I have had no issue with warranty repairs in the past. Just my rant, by they way
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Oil leak vs. Seepage issue
    I would take it to a different dealer...
    Mine had a seep at the case half seal...and a seep at the rear of the real valve cover.
    It had never dripped on my concrete garage floor... there were no spots on the floor.
    They pulled the engine and fixed it.
    Texas Jim
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,683
    I would recommend taking the vehicle to a different dealer to have them diagnose it, as well. If you would like me to call and make an appointment just let me know your VIN, name and the name of the other dealer and I will be more than happy to assist you.
    Breanne
    May 2011
    WARREN, MICHIGAN
    60
    24
    Well my seepage issue is now leaving two to three inch puddles of oil. I will drop the car off at the dealer in a couple days and see if they will finally repair this the correct way. I will keep everyone updated
    2007DTSLUXI is offline Cadillac Owners Member
    Automobile(s): 2007DTSLUXI
    Oct 2011
    Martinsburg, WV
    36
    56
    I was told that if you switch to synthetic oil that it will upgrade that seap to a leak for sure. Not sure it is factual information, however I was told that certain minerals in regular engine oil keep our gaskets and seals swelled up and when you switch to synthetic that it lacks those minerals and will causes those seals and gaskets to deflate a minute amount which has a tendancy to spout some leaks lol...
  8. Remove Advertisements
