Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 49
Thread: random stalling issue 2006 DTS
  1. #31
    Mar 2010
    Detroit, USA
    12,711
    Re: random stalling issue 2006 DTS
    Phatalac, I am so sorry to hear that you experienced this! Have the power loss/misfire been happening after your dealer trip? I would be happy to investigate this further for you if you wish or locate alternative dealerships near you; please send me a private message anytime!
    Best,
    Katie
    Cadillac Customer Service
  2. #32
    Phatalac is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS LUX III
    Oct 2011
    27
    130
    i am going to update this, i have switched dealerships and received much better service. the new dealer found a i had a bad oxygen sensor and replaced that, car has not stalled since! i also cleaned the throttle body again very well.
    I am still having issues with a misfire under load at low speeds with the AC on. i found the code P0358 ignition coil H primary/secondary circuit. it only seems to misfire if i am in drive at a stop light with the ac on it will how ever do it with the ac off just much less often. I need to know what it the number 8 cylinder on the northstar engine so i can run a few more tests. any help is much appreciated
  3. #33
    Mar 2010
    Detroit, USA
    12,711
    Ah! Thanks for the update, Phatalac. I'm happy that your stalling concerns appear to be resolved! I would recommend consulting your new dealership for coding information, or I would be happy to consult my internal resources on your behalf (just send me a PM with the last eight of your VIN for me to research further).
    Best,
    Katie
  4. #34
    Oct 2011
    27
    130
    any body know what the number 8 cylinder on a northstar is?
  5. #35
    mike5514 is offline Cadillac Owners Enthusiast
    Automobile(s): 97sls,09dts
    79
    878
    Front bank drivers side (First cylinder on your right as your facing the front of engine)
  6. #36
    79
    878
    1357
    2468
    front
    firing order 12734568 Almost certain.Mike
  7. #37
    Oct 2011
    27
    130
    Woo its fixed number 8 coil and plug were toast. Coil killed my plug. Thanks for the help
  8. #38
    bjm6887 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac dts performance
    Apr 2013
    10
    hey all, i think im having a similar issue with my 06 dts. perf. misfires at idle, p0300 stored, acts like it will stall. traction control light will then come on with stabilitrac message, then firm shifts. acts the worst at idle and just above, runs ok after that. new plugs, 2 new coils, new maf, new map sensor. still does it. hoping it is a pcm software issue that can be updated, maybe new pcm. ive been a mechanic for 20+years and it has me stumped.
  9. #39
    Oct 2011
    27
    130
    dealer has also replaced my oxygen sensor twice now. but since the first replacement 02 sensors went in i haven't had it stall once since.
  10. #40
    Oct 2014
    My 2006 DTS has stalled on me twice this week. Previously I noticed at idle a few times that the idle speed would dip and then recover. Everything I am seeing online says the crankshaft sensor is most likely the issue. I had it checked out with a scan tool 2 days ago and everything was good-no codes, no engine light, crank sensor sawtooth pattern was very good- however this looks like an intermittent issue. I mostly am concerned with getting stranded. Does anyone know if that is likely? PS I am also speed limited to 80mph. Is that a seperate issue?
    My 2006 DTS has stalled on me twice this week. Previously I noticed at idle a few times that the idle speed would dip and then recover. Everything I am seeing online says the crankshaft sensor is most likely the issue. I had it checked out with a scan tool 2 days ago and everything was good-no codes, no engine light, crank sensor sawtooth pattern was very good- however this looks like an intermittent issue. I mostly am concerned with getting stranded. Does anyone know if that is likely? PS I also have a speed limited to 80mph issue but I think this is related to an issue with rear suspension?
  11. #41
    MM2Sandoval's Avatar
    MM2Sandoval is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS, R.I.P. 2001 Cadillac DeVille
    Jan 2012
    Houston, TX
    30
    180
    Has anyone found a resolution to this? I am not starting to have the same issue on my 06. The last things I have done to the car was install a sound system, it stalled on me when driving away from a stop sign. Loss of steering and engine shut off. Drove out of town Friday and it would also dip and recover while doing maybe 75. I had it on cruise control so I assumed it was just the CC slowing down to stay at the speed I set it to, but when I drove back home yesterday, it did it again. It would feel like a very brief loss of power then quickly recovered. This morning while dropping off my kid at school...it shut off while it was in drive an foot on the brake. I added that marvel mistery gas additive as directed and thats when I noticed the problem got worse. Again...has the problem been pinpointed to the exact issue?
  12. #42
    Jan 2012
    Houston, TX
    30
    180
    2006 DTS Random Stalling
    There was a thread with this exact issue that was last updated in 2014. I gave it a shot to see if someone may respond. Well here it is again.
    Come to think of it, it has stalled a few times while in park. Twice Friday, it almost stalled when I got to the dirt road leading to my parents' property. I got out to get my youngest daughter so she can sit on the arm rest and maybe see some rabbits, deer or hogs. As I got her out, I walked infront of my car and it almost died, then the RPM's increased to keep the car on. No MIL. Should I go check if there are any codes in the car without a check engine light?
  13. #43
    527817 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS
    May 2014
    61
    107
    this could be a TPS issue given the car's age.
    next time use a razor knife on the battery. there will be no sand residue and a much cleaner terminal. this is marine trick.
    Cadillac customer service:
    this sounds like the issue that I had with the driver's seat heater seat bottom never getting warm. it was never fixed and they left off the passenger side seat back which I reinstalled. Now I let my mechanic fix everything. He even found that the engine mounts were broke after the 50k warranty was up and the dealer never found it. probably because they never looked. I just hold my breath with 80k on it. The new GM cars are not nearly as good as the cars in the 1970's even though much technology has improved. however the quality issues are worse.
  14. #44
    Jan 2012
    Houston, TX
    30
    180
    Quote Originally Posted by ddowers View Post
    Ok i can see it being this but has it been confirmed by someone else?
    What's this for?
    What does this have to do with the car stalling??
  15. #45
    May 2014
    61
    107
    the dealer giving you a run around.
  • You may not post replies
