Temperature Gauge question
Results 1 to 11 of 11
Cadillac DTS Forum - 2006 through 2012 Discussion, Temperature Gauge question in Past Cadillac Vehicle Discussion; Guys, where does your temperature gauge set at after your car is warmed up? My old impala set exactly in ...
    phigment is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Nov 2010
    199
    Guys, where does your temperature gauge set at after your car is warmed up? My old impala set exactly in the middle of the gauge. The first time I test drove my DTS I thought maybe it was starting to over heat because the needle settles above the half way mark. Lately it seems to inch a little higher than usual and then come back down. Just wanting to make sure what is normal. Many thanks.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Temperature Gauge question
    Mine will occasionally go to about a needle and a half above the halfway mark, in really hot weather or if I have been driving VERY aggressively in the mountains at relatively low speed and shifting back and forth from 1st to 2nd and then back to 1st repeatedly.
    Other than that, it stays right in the center mark with the top of the needle about 1/3 it's width above the center mark.
    Remember, if you are "NOT" using the AC, the fans do not come on till it reaches 226F.
    If you ARE using the AC, the fans are on when you are below about 35 MPH.
    Texas Jim
    Tomko's Avatar
    Tomko is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Lux III (assembled January 31, 2008)
    Jul 2007
    South of 46
    270
    My temperature indicator behaves precisely as Jim has described.
    Leo George Jr is offline Cadillac Owners Member
    Automobile(s): 06 DTS Raven Black - 05 CTS-V Raven Black
    Jan 2009
    Moneta, Va.
    69
    My temperature indicator behaves precisely as Jim has described also.
    ogbuehi is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville, 2011 DTS
    Jul 2004
    washington d.c.
    852
    Mine behaves. Probably not as exact as others Cadillacs but not in any way to warrant any concern.
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Quote Originally Posted by Superjim View Post
    This happens every fall... people who have been using the a/c full time suddenly stop using the a/c and the temp needle starts to move a bit on them ... and they freak out
    Mark58 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 DTS Performance
    Aug 2008
    69
    188
    Can you imagine if we actually had analog gauges for temp and oil pressure how many concerns that would raise?
    Rusty058's Avatar
    Rusty058 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS LuxII
    May 2010
    Milford, Connecticut.
    58
    141
    Quote Originally Posted by Leo George Jr View Post
    Same here
    Jan 2009
    Moneta, Va.
    69
    Mine stays the same year round, a/c or not.
    kingphil69 is offline Cadillac Owners Fanatic
    Jan 2005
    123
    Sits right at or a needlepoint above middle with the ac on.
    ac off, hovers needlepoint above and slowly works its way up to one line above middle, but never higher than that. if i'm crusing, it stays in the middle. traffic light or drive through, it'll come to the first line above center, fans come on, and it comes back to center. knowing how sensitive these engines are to overheating i find myself looking at it more than i want to. however, it's been that way since i've had it. even had the dexcool flushed and refilled by the dealership (i know... i know...) just so i KNEW it didn't have sludge in it. i plan on draining and refilling the dexcool every year like every other caddy i have, so it has no chance of building up and stays fresh.
    sirchico is offline Cadillac Owners Member
    Nov 2013
    1
    I smell somthing wrong
    sirchico, This is a two year dead thread. Please do not mindlessly test your new membership. Thanks, CF Staff.
  14. Remove Advertisements
