How to change headlight bulb(s) on a 2006 DTS - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 66
Like Tree14Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, How to change headlight bulb(s) on a 2006 DTS in Past Cadillac Vehicle Discussion; Step 8 says to remove the nut behind the light in the upper cave - is that step necessary? I ...
  1. #46
    kenkern is offline Cadillac Owners Member
    Automobile(s): DTS
    May 2013
    1
    Re: How to change headlight bulb(s) on a 2006 Cadillac DTS
    Step 8 says to remove the nut behind the light in the upper cave - is that step necessary? I removed the plastic skid plate type thing and it was easy to access the bolt and nuts mentioned in step seven without having to take the tires off....
  2. #47
    cadillac_guy21's Avatar
    cadillac_guy21 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 Cadillac DTS, 1966 Cadillac Sedan DeVille
    Jul 2012
    Savannah , Ga
    197
    ken kern how did you do it cause mine just went out
  3. #48
    phigment is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Nov 2010
    199
    I believe you are correct. Step 8 is not required. When I did this, it was my first time and it "looked" like that nut was holding the headlight assy in.
  5. #49
    Scarfish is offline Cadillac Owners Member
    Automobile(s): dts
    Nov 2009
    4
    I just wanted to thank you for the great instructions. You saved me a lot of time and money.
  6. #50
    Castro420 is offline Cadillac Owners Member
    Automobile(s): 1984 Seville, 2007 DTS
    May 2013
    33
    3
    Does nobody know how to change out the side orange parking light?
    How do I change the orange parking light?
  7. #51
    grullon10's Avatar
    grullon10 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 cadillac dts
    Dec 2012
    46
    553
    Those light are led they can't be change . If they are off that mean that the wires are bad. But if you only want to change it because you don't like they color they plastic on the head light that orange not the bulb. If they are not working also check the white parking light on the front. Is also off it may be a harness problem it is very easy to check. There is a plug between the fuse box and the coolant tank. Unplug that with a tester test the plug . My car had a issued with the right side it was not comming on. The right side wire color for it is purple. The left is different we had to jump it from the plug to the light to make it work. Good lk.
  8. #52
    revolcallidac is offline Cadillac Owners Member
    Automobile(s): 07 Escalade
    Aug 2013
    31
    Or...for the Parking light/DRL bulbs...(the ones the OP changed)...you could do what I just did in <30 minutes....just reach down beside the headlight, take the one T20 torx screw that holds that little white plastic funnel looking thing in place (it only serves to be a guide for the technician's adjuster tool to hit the right spot), remove the little plastic thing, grip the socket, gently twist it and pull it out. Pull out old bulb, push in new bulb, stick the socket back in place and gently twist it in the opposite direction to lock it in. Put the white plastic thing back on with the one T20 torx screw, test your work, then put the black cover back on. Done!
    NOTE....if you have large wrists and large stubby fingers, you won't be able to do this...I'm a pianist with skinny wrists and long fingers.
  9. #53
    May 2013
    33
    3
    Has anybody changed out those orange led lights on the headlights
  10. #54
    May 2013
    33
    3
    This is the one I'm having issues with
  11. #55
    kadylac1's Avatar
    kadylac1 is offline Cadillac Owners Member
    Automobile(s): 2008 CADILLAC DTS
    Oct 2012
    SAN DIEGO, CA
    83
    Is this the same process used to replace the front turn signal bulbs?
  12. #56
    kadylac1's Avatar
    Oct 2012
    SAN DIEGO, CA
    83
    Quote Originally Posted by phigment
    The steps are the same for all DTS's as far as I know. The entire assembly must be removed in order to replace any of the bulbs. There is no access to the back of the headlight assembly from within the engine compartment. As far as I could see the entire assy is covered.
    Thanks phigment. I just answered my own question.
  13. #57
    ogbuehi is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville, 2011 DTS
    Jul 2004
    washington d.c.
    852
    It definitely is. I upgraded my turn signals to LEDs and had to go through the same process. I'm just glad I've never had to replace the headlights.
  14. #58
    khall4u44 is offline Cadillac Owners Member
    Nov 2012
    4
    where did u get the little round parking hid blubs & whats the part numbers original & hid?
  15. #59
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    No such thing as HID parking lights. The bulbs are 194's.
  16. #60
    Automobile(s): DTS
    Nov 2010
    199
    I swapped the 194's out for LEDs. That is why they are bright. If that is something you are looking at doing, I would strongly recommend purchasing quality LEDs. The cheap ones will not last long enough to make it worth your while.
  17. Remove Advertisements
