How to change headlight bulb(s) on a 2006 DTS - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 66
Like Tree14Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, How to change headlight bulb(s) on a 2006 DTS in Past Cadillac Vehicle Discussion; Found this doing a google search: http://autolumination.com/194.htm That's for a 194 bulb which is pretty much the same as a ...
  1. #16
    phigment is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Nov 2010
    199
    Re: How to change headlight bulb(s) on a 2006 Cadillac DTS
    That's for a 194 bulb which is pretty much the same as a 2825 dimension wise.
  2. #17
    hand183 is offline Cadillac Owners Member
    Automobile(s): 2006 dts
    Sep 2011
    60
    1
    YOU ARE THE MAN!!!!! $562 for a pair of bulbs at the dealer and 3 hours worth of labor @ $90 an hour here in Wyoming. Went to the site on Amazon and got a pair of bulbs for $84. Followed your excellent instructions and I was completely successful. Saved me about $800 bucks. I'd buy you dinner and a few brews if you were out here. Thanks a lot for taking the time to put out the instructions. If I had been introduced to the engineer who designed that set up while I was halfway through the project, there would be a big blood spot on my garage floor now!!!!
    cl10473 likes this.
  3. #18
    Automobile(s): DTS
    Nov 2010
    199
    Im really glad you found it useful. That was my first "How to" anywhere on the net so Im glad I did it.
  5. #19
    Tonyny's Avatar
    Tonyny is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Dec 2003
    Clermont, Florida
    62
    143
    Quote Originally Posted by ltdltc View Post
    Doesn't seem all that terrible.
    All that to change a bulb?
  6. #20
    ogbuehi is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Deville, 2011 DTS
    Jul 2004
    washington d.c.
    852
    What size jack stand did you use to keep your DTS propped? I'm getting a FSM for my birthday and am getting ready to replace all the fog lamps, cornering lights, and turn signals with LED bulbs.
  7. #21
    Automobile(s): DTS
    Nov 2010
    199
    I use the 3 ton jack stands from walmart. They are about 30 bucks for the pair and do the job well.
    http://www.walmart.com/ip/Torin-Jack...-Pair/14560047
  8. #22
    Jul 2004
    washington d.c.
    852
    Thanks. I needed the height because I've always gotten the wrong size jack stands. The Cadillac suspension seems to be so low to the ground I had to bu a professional low level jack just to be able get under the car and be able to jack the car high enough to change out wheels and such.
  9. #23
    davidcadillac is offline Cadillac Owners Member
    Automobile(s): 2007 DTS Luxury II
    Aug 2011
    50
  10. #24
    383 LT1 SS is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Impala SS 383 LT1 2011 Escalade ESV 2008 DTS
    May 2010
    NW Burbs of Chicago
    197
    I had the amber DTR lamp go out on my car. This lamp is also the front turn signal. It was the right side lamp that burnt out. I tried to get at this lamp from the top and I could probably get the bulb out but I was worried that I would not get it back in. I took the car to my dealer and they charged me $100.00 to swap in a new bulb. I wish I would have found this thread sooner. This design is not very good for the DIY types.
    383 LT1 SS
  11. #25
    Aug 2011
    50
    Excellent write up. I replaced the parking lights with LEDS http://www.v-leds.com/Interior-LED-B...96345-1-2.html
    They look awesome and factory. Directions made this a simple swap
  12. #26
    pauly94 is offline Cadillac Owners Member
    Automobile(s): '06 Cadillac DTS, '09 Cadillac Escalade ESV
    Feb 2012
    22
    1
    Awesome write up, but i had a small problem.
    Did any of you have a problem with something that looks sorta like a bolt connected to the frame behind the light? You can't unscrew it, and it broke off. Would this cause any problems?
  13. #27
    Jul 2004
    washington d.c.
    852
    Can you take a picture of it? I still have mine apart and I might be able to help you since I know where a lot of the bolts go and do.
  14. #28
    cndnate is offline Cadillac Owners Member
    Mar 2012
    36
    Thank you for posting write up.
    I have a question: will any D1s bulb work? I usually buy parts from rockauto, however they list 3 part options, with a great range in prices.
    Any reason why I should pay for the more expensive ones? I am only replacing one side.
    2006 CADILLAC DTS 4.6L V8 : Electrical-Lamp & Socket : Headlamp Bulb Wiki Price Alternate
    WAGNER Part # D1S Halogen Capsules
    OE TYPE; Dual beam $60.10
    Part In Cart
    GE Part # D1S Standard Replacement
    Dual beam $80.87
    Add Part
    ACDELCO Part # 25735604
    BULB,HDLP 4 DOORS CAD$163.92
    p.s. where did you order your headlight bulbs from?
  15. #29
    hurtlocker1242 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Jan 2013
    50
    Everything worked like a champ! This was very helpful - THANK YOU!!!
  16. #30
    Automobile(s): DTS
    Nov 2010
    199
    Very welcome.
  17. Remove Advertisements
