Oil leak fixed ! But i have a question !
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Cadillac DTS Forum - 2006 through 2012 Discussion, Oil leak fixed ! But i have a question ! in Past Cadillac Vehicle Discussion; Had the common Dts oil leak fixed under warranty and picked the car this evening but tech guy had called ...
    quebec#1 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts Cadillac 2000 sts balck on black
    Nov 2008
    montreal quebec canada
    45
    147
    Had the common Dts oil leak fixed under warranty and picked the car this evening but tech guy had called it a day when i picked up the car.
    I was told that the whole engine needs to be lifted out of the car.
    My Question is do they have to take off the front fenders ?
    I just noticed that one of the front fenders is not aligned with the door.
    (gap) This was the only thing repainted on the car from the previous owner . It might have been like that before i brought the car in ?
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: Oil leak fixed ! But i have a question !
    The fenders do not have to come off to remove the engine.
    To fix a valve cover oil leak... the engine does not have to come out of the car.
    They usually lower the front part of the cradle and tilt the engine forward.
    To take the engine out of the car... it is removed from the bottom... not from the top like in the old days.
    Jim
    Nov 2008
    45
    147
    Thank you Jim ! So i guess they dont have to take of the struts ? Seems like a softer ride for some reason !
    Sorry for the stupid questions ! Its been a bad week so far ! Cracked ribs during a hockey game, pain killers ect. Gilfriend of 8 years flew off with one of my best friends ect..
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by quebec#1 View Post
    Sorry to hear about all your bad luck... and it all coming at the same time...
    You are correct.. the struts DO NOT have to come off..
    There is a SLIGHT possibility that when the battery was disconnected... all of the computers reset to defaults.
    That might cause the ride to be a little different if you have the Performance Sedan with the MRC suspension... otherwise, there should be no difference in the ride.
    Jim
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Quebec#1,
    Glad to hear you got your vehicle fixed. It would be up to the dealership if they had to take them off or not. I would encourage you to speak with them to confirm if they did or not.
    Thank you!
    Elizabeth, Cadillac Customer Service
    phili1 is offline Cadillac Owners Fanatic
    Automobile(s): 2017 Premium Luxury/ Stellar Black Metallic & Sahara Beige/Jet Black
    Dec 2009
    189
    I had valve cover and oil pan gaskets. They lowered my motor from bottom of car. I had a non- GM warranty. They covered all but $100.00. cost $4100.00
    Nov 2008
    45
    147
    Quote Originally Posted by phili1 View Post
    Phil it looks like they also did the same to mine valve cover & oil pan gaskets paid the $100 deductible tech guy said it would have been over $3000 if i had no warranty. Also looks like they changed the antifreeze and of course oil & filter and added freon. Written on bill that it was a 24 hour job ?
    Dec 2009
    189
    I checked my bill and I had 25.3 hours of labor. I forgot they replaced the steering rack also. If I had to pay for that bill, it would have still been sitting.
    REVELATION13 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac DTS
    May 2011
    40
    108
    What is the steering rack ?
    My car makes a slight knock when making left and right turns, I can feel it thru the steering wheel.
    Is that the same thing you were experiencing?
    Dec 2009
    189
    That might be a tie rod or ball jiont, most of the time. The steering rack is called the sterring gear in our DTS, which is part of the steering. Sometime they will make some niose, but mines had a small leak at times and the power streering fliud was blowing back onto the exuast and had a burning smell some of the time.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Quote Originally Posted by REVELATION13 View Post
    I had the steering rack replaced on mine.
    When sitting still... if you moved the wheel right or left, there was a slight "CLICK" and you could also feel it in the wheel.
    Texas Jim
    Kevin Wong is offline Cadillac Owners Member
    May 2003
    3
    If the vehicle hoist lift points are positioned too closely to the lower fender area, the upward force on the fender mounts may cause the fenders to bow outwards, resulting in a door to fender misalignment. This is also a weakness in the 2000-2005 generation and related models.
    May 2011
    40
    108
    Quote Originally Posted by Superjim View Post
    Texas Jim
    i will have to check that out ! So while the car is on and at a stand still turn the wheel right and left ?
  16. #14
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    On mine... sitting still with the engine running...
    You could move the wheel a couple of inches from center to either the left or right and feel a VERY SLIGHT catch in the wheel.
    And if you listened REALLY GOOD, there was just a slight CLICK or TICK at the same time the wheel had the little catch in it.
    Texas Jim
  17. #15
    Lev Blekher is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS Performance/1996 Dodge Stratus ES
    Sep 2010
    29
    212
    Mine does this to the right but I can never get it to do it right when the tech is there.
  18. Remove Advertisements
