Code P 0420 Catalytic Converter
Results 1 to 6 of 6
Cadillac DTS Forum - 2006 through 2012 Discussion, Code P 0420 Catalytic Converter in Past Cadillac Vehicle Discussion; I have replaced the Catalytic Converter on my 2006 DTS Using a code reader turned off check engine light. Light ...
    SteveBeard is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Oct 2010
    79
    4
    Light comes back on after driving car two or three times.
    Checked code and it reads
    PO420 Catalysts Efficiency Below Threshold.
    Things I have been told:
    On a 2006 DTS the check engine should should go off with using a code reader to reset??
    Also told could have an O2 sensor bad?? (How would I know?)
    The light has been reset 5 fives now.
    Any suggestion or thoughts.
    Thanks
    Steve
    ltdltc's Avatar
    ltdltc is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS4 Performance Sport Wagon
    Jun 2003
    MA
    35
    490
    Re: Code PO420 Catalytic Converter
    May want to check the voltages on the O2 sensor.
    I had my Catalytic Converter replaced a while back under the CPO warranty as my CEL went on (P0420) and it caused the car to not run right (loping idle and reduced power under acceleration).
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    2006 had a software update to prevent false instances of a P0420.
    Faulty oxygen sensors would not cause a P0420 because before the test can run for P0420 all the Oxygen sensor self tests MUST pass.
    Did you replace it yourself or have someone do it for you?
    Be sure you have no exhaust leaks, if fresh air is getting in there it can affect the diagnostics and set a false cat code.
  5. #4
    Oct 2010
    79
    4
    Thanks for the help. I had it replaced at a muffler shop. Not Cadillac service center. I will take it back again have them look at it.
  6. #5
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    They are required by law to provide you with a functioning cat for 5 years or 50,000 miles after they install a replacement.
    If the light comes back on, take it back.
  7. #6
    bjm6887 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac dts performance
    Apr 2013
    10
    I believe there is a re flash for the ecm to correct over sensitive calibration
  8. Remove Advertisements
