door chimes-07 dts
Results 1 to 8 of 8
Cadillac DTS Forum - 2006 through 2012 Discussion, door chimes-07 dts in Past Cadillac Vehicle Discussion; Came home yesterday, backed into garage as normal, shut off ignition and removed keys, on opening drivers door I noticed ...
    jackd is offline Cadillac Owners Member
    Automobile(s): 05srx n*07 dts
    Nov 2009
    40
    door chimes-07 dts
    Came home yesterday, backed into garage as normal, shut off ignition and removed keys, on opening drivers door I noticed that the chimes were ringing which normally does not happen. now every time I open the drivers door the bells start to ring. It does'nt chime with any other door open and goes off as soon as the drivers door is closed. It's very annoying and I was wondering if anyone else has had this problem.
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 DTS Platinum
    Jun 2006
    Ft. Worth
    72
    4,633
    Re: door chimes-07 dts
    I have not had that problem...yet...
    Evidently it thinks the keys are still in it or that the lights are on...
    Have you tried the other ignition key in it??
    Texas Jim
    Nov 2009
    40
    Thanks for your reply,Jim. I tried the other key and nothing changed. It probably means a trip to the dealer, still under warranty so that helps.
    Superjim's Avatar
    Jun 2006
    Ft. Worth
    72
    4,633
    Being under warranty is great.
    That means that it will cost nothing to get it fixed.
    Please report back on what they find wrong with it.
    Texas Jim
    Nov 2009
    40
    Went to the dealer yesterday and of course as soon as I arrived the chimes stopped when the door was open, they looked at it anyway and found nothing. I will just have to wait to see if it acts up again. They did however find a slight oil leak and the rear high mount brake light has sections out on the LED strip. They ordered a new LED strip and put some dye in the oil, will be going back friday to find out where the oil leak is and have the new brake light strip installed. I will repost when I find out more.
    dadnova is offline Cadillac Owners Member
    Apr 2011
    Spray some Grafite or some other good dry lubricant into the lock, just getting stuck
    ltdltc's Avatar
    ltdltc is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS4 Performance Sport Wagon
    Jun 2003
    MA
    35
    491
    Bet the oil leak is coming from the rear valve cover (left side of engine looking at the front of the engine block ). Also the door chimes should be something that can be disabled. The performance sedan I have now is much louder then my Lux II was. Really irritating and unnecessary feature in my opinion.
    hazcaddy's Avatar
    hazcaddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 XTS4, 2010 DTS (gone), '07 STS4 (gone), '03 DHS (gone)
    Feb 2005
    Oakville, ON
    508
    Your chimes will sound if the headlight control is not on Auto or Off. Could that have been the case?
  11. Remove Advertisements
