rear door panel removal
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Cleetorn
Cadillac DTS Forum - 2006 through 2012 Discussion, rear door panel removal in Past Cadillac Vehicle Discussion; I have a 06 DTS and the rear door window fell down. I need instructions on how to remove the ...
    skyliner is offline Cadillac Owners Member
    Automobile(s): 06 DTS
    Aug 2010
    62
    Questionrear door panel removal
    I have a 06 DTS and the rear door window fell down. I need instructions on how to remove the door panel. I tried but didn'd want to force it. Any help would be good. Thank You
    383 LT1 SS is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Impala SS 383 LT1 2011 Escalade ESV 2008 DTS
    May 2010
    NW Burbs of Chicago
    197
    Re: rear door panel removal
    Get a door panel removal tool. Should be available at your local autoparts store.
    383 LT1 SS
    Cleetorn is offline Cadillac Owners Member
    Automobile(s): Black 2006 DTS
    Sep 2012
    Utah
    4
    ***tool in hand, scratching head*** Great instructions! Thanx! That helped a lot -- NOT! Perhaps some actual instructions would have made a difference instead of just advising to get a tool as though that would take care of the whole project.
    MM2Sandoval likes this.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Behind the chrome pull handle is a cover that needs to be removed. I use a pick. There is one phillips head screw to remove. Next get the trim removal tool and pop the many clips that hold the door panel on. They are around the perimeter of the panel. Once the clips are unfastened hold the door panel away from the door and lift upward. There are two clips that are behind the door pull that slide into two slotted clips. I hope that makes sense. For reinstallation slide the metal part of the clip into the plastic part of the clip and press firmly to engage it into the door panel
    Don
    danog is offline Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    428
    door pan.gifComponent Name
    1 Rear Side Door Locking Rod Knob
    2 Rear Side Door Pull Handle Plate
    3 Rear Side Door Pull Handle Screw
    Notice: Refer to Fastener Notice . Tighten 2.5 N·m (22 lb in)
    4 Rear Side Door Trim Panel Retainer (Qty: 8)
    5 Rear Side Door Armrest Retainer Clip (Qty: 2)
    6 Rear Side Door Trim Panel Assembly
    Tip 1. Use a J 38778 Door Trim Clip Remover to aid in the removal of the door trim panel.
    2. After releasing all the retainers along the outer perimeter of the door trim panel, hold the panel away from the door and lift up to disengage the 2 clips that anchor the armrest into the door sheet metal.
    3. Prior to re-installing door trim panel, re-attach the 2 armrest clips to door sheet metal.
    4. Disconnect the electrical connectors
    REMOVE THE Rear Door Water Deflector
    Press the center pin inward to release the retainers There are 11 I think.
    after removing the deflector Loosen 2 10mm nuts holding the glass to the reg
    pull the window upward and use duck tape to hold it up.
    Sep 2012
    Utah
    4
    Your instructions make plenty of sense but I can't seem to get the two interior clips to pull up to disengage from the door. I'm afraid if I pull up TOO hard, I might break something that would be better unbroken. Some special ideas before I go much further?
    ffrog is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS Performance
    Apr 2010
    Phila, PA area
    78
    269
    Google “REMOVE DTS DOOR PANEL”. This will bring up a couple of videos for a CTS. The process should be about the same.
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Quote Originally Posted by Cleetorn View Post
    You need to pull the door panel outward to clear the green clips that are around the perimeter. While holding it out slide the door panel upward. This will make the metal armrest clips slide out of the plastic clip that is attached to the door shell. The two clips that are behind the arm rest are made up of 4 pieces. Twp plastic pieces that are attached to the door shell and two metal pieces that press into the door panel. The metal part slides into grooves that are on the plastic piece.
    Don
    Sep 2012
    Utah
    4
    Got the whole thing apart and the reg/motor out. It looks like the only thing that's broken is the plastic where the cable pinches to the slide. Is there a good fix for this or am i going to be into getting a whole new assembly just for the pinch point?
    Nov 2011
    428
    The most that you will break are some of the green clips. Just pull both sides out and lift up. Once you get the door panel off you will understand.
    Nov 2011
    428
    You need to replace the reg. It comes with or with out the motor
    ruaskier2 is offline Cadillac Owners Member
    Aug 2005
    6
    Hi All, I'm following as I'm in the same boat. I have the panel off. My issue is that the door switch will not activate the window. I have the 2 wire plug removed from the motor. I see that the grey wire from the plug is the down and the blue wire is the up. I ground my volt meter and touch each of the two wires on the plug and I get ~ 12.5 V from each wire when I use the door switch. Note: I do hear a loud click each time from the black window module. Also, if I apply 12V to both prongs on the motor itself, I can get the track to move depending on witch polarity I use. The motor works, I get power from the plug, yet when together, I get nothing still. Thoughts anyone? I will remove the other back door panel to figure this mess out. Thank, great site!
  15. Remove Advertisements
