Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Thread: Whitewall tires
    NewHopeMan is offline Cadillac Owners Member Cadillac(s) I Drive: 1989 DeVille, 2006 DTS
    Mar 2010
    3
    Whitewall tires
    Anyone have a source for white wall tires for 2006 DTS with 17" wheels? Other than Vogues, that is.
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    Southern is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: 2008 DTS LUX III - Gold Mist w/Light Linen Leather and cocoa
    Oct 2005
    Ft Myers Florida
    72
    1,498
    Re: Whitewall tires
    Good question. I believe that Goodyear Comfort Treads USED to come either BSW or thin WSW.
    I know that I had to go to a different size....I am running 225/60-17 Michelin MX4s with the WSW. That's a difference of 1.7%. So when my Speedo says 60, I am actually going 61.0 Most people try to keep within 3%.
    TulsaVic is offline Cadillac Owners Fanatic Cadillac(s) I Drive: '08 DTS Performance
    Jan 2008
    Tulsa, OK
    63
    222
    Re: Whitewall tires
    According to their website:
    Tire Rack offers whitewall or whitestripe tires in the following models.
    Bridgestone Turanza EL400
    Continental ContiProContact
    Dunlop SP 60
    Goodyear Assurance ComforTred
    Goodyear Eagle LS
    Goodyear Integrity
    Goodyear Radial LS
    Kumho Solus KR21
    Michelin Energy LX4
    Michelin Symmetry
    Yokohama Aegis LS4
    I don't believe there's that much available. But you might contact them.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    Mar 2010
    3
    Re: Whitewall tires
    Can you change the size tire you use? I see a plain(er) whitewall on funeral vehicles and I like that simple narrow stripe rather than the white/gold on the Vogues. Also I've heard not-so-good things about them. Maybe I should just sneak around some funeral homes and check out their tires.
    Oct 2005
    Ft Myers Florida
    72
    1,498
    Re: Whitewall tires
    Sure you can change tire sizes. Within Reason. I thought I said that in my post.
    Go to http://www.miata.net/garage/tirecalc.html
    Put your stock tire size in 235 55 17 (The 235 is the Width in mm, the 55 is the ratio for the sidewall height (55% 0f 235mm will give you a sidewall height of 5.1 inches) and 17 is the diameter of the wheel)
    And then put in the size you are wondering about in New Tire.
    You CANNOT change the "17" with out changing wheels.
    As I said, keep it within about 3% and you will be good to go....except for clearance.
    Everybody might have a different idea, but I wouldn't go wider than 255mm. You don't want the new tire to rub on the fender or fender well....
    And I wouldn't go with a ratio of less than 50.... 40% or less would be a harsh ride.
    There would be nothing wrong with checking out the tires on a hearse. Ask first!
    HartfordGuy's Avatar
    HartfordGuy is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 2007 Cadillac DTS. Raven Black, Titanium interior.
    Oct 2009
    Hartford, CT
    44
    109
    Re: Whitewall tires
    Here ya go; http://www.tirerack.com/tires/tires....omCompare1=yes
    Goodyear Eagle LS P235/60R17
    I am thinking of going to this narrow stripe whitewall when it's time to replace my tires.
    Mar 2010
    3
    Re: Whitewall tires
    Great, that's what I was looking for. Thank you!
    Oct 2005
    Ft Myers Florida
    72
    1,498
    Re: Whitewall tires
    I would still be more likely to buy a set of Goodyear Assurance ComforTreads. They ARE still avail in Narrow White Stripe and they are avail in the DTS size and they cost about the same as the Eagle LS.
    Why? Because it is a better and quieter tire.
    And while the Eagle LS is rated #24 out of 28, The ComforTread is rated #6 out of 24.
    7 out of 10 ComforTread owners would buy it again while only 3.8 out of 10 Eagle LS owners would....
    Take a look at
    http://www.tirerack.com/tires/tires....nce+ComforTred
    And note on the left side of the page "Other Sidewall Styles" Narrow White Stripe 0.5
    But you pays your money and you takes your choice.
    Oct 2009
    Hartford, CT
    44
    109
    Re: Whitewall tires
    The Goodyear Assurance Comfortreds are a nice tire. But unfortunately the narrow white stripe is only available on the P225/60R16 tire. See link to Goodyear site: http://www.goodyeartires.com/goodyea...area=Passenger
    That's because they were the OE tire (whitewall) for the Crownvic, Grand Marquis, Towncar series.
    The 17" Goodyear Eagle LS is the OE whitewall tire supplied to the Funeral car industry.
    I would tend to believe the info posted at the Goodyear tire site rather than the tirerack site.
    Oct 2009
    Hartford, CT
    44
    109
    Re: Whitewall tires
    Quote Originally Posted by Southern View Post
    The Comfortreds are passenger car tires. The Eagle LS are listed at Goodyear as a "SUV-minivan" tire. There is a whitewall version of it because they were spec'd out for Limousine and Hearse use. The commercial duty requirements dictated a XL load rating. Perhaps that is why they are louder to run?
    As you said, it comes down to choice. If you want the quietest and smoothest the Comfortreds may be the one. But if you want a narrow white stripe, you are limited to the Eagle LS in the 17 inch size.
    Oct 2005
    Ft Myers Florida
    72
    1,498
    Re: Whitewall tires
    Right you are. Seems odd that they would make the stripe only avail on certain sizes, but that's the way it is.
    I checked my tires and they are LX4s. They are "OK". Maybe rated a bit higher than the LS but not a lot.
    I will give up the stripe when it comes time to replace them and I will go with whatever is the quietest tire since the biggest noise problem with the DTS is road noise, IMO.
    The DTS is noisier than my Mercedes SUV!
    Oct 2009
    Hartford, CT
    44
    109
    Re: Whitewall tires
    Southern; Can you post a photo of your Gold Mist DTS with the whitewalls?
    Oct 2005
    Ft Myers Florida
    72
    1,498
    Re: Whitewall tires
    Well, I'll try. Have been having problems uploading pix. Funny, I can upload to Photobucket, but not to forums.........
    Hey! Waddayaknow! It worked!
    What strange problem. If I try to upload directly from my desktop to this site, it says that it is not a proper Imagetype (It's a jpg).
    But photobucket takes it just fine and then DLs it here just fine.
    And it is not this site's problem.
    I have two other sites that are also not accepting my photos......
    And ALL of these sites previously had no problem........ Hmmmmn.......and I am a retired Computer guy! (Big stuff tho, not these little PCs and Macs....)
  16. #14
    z06bigbird is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,585
    Re: Whitewall tires
    Ask any old fart about porta-walls for cars. Popular in the late 50s and early 60s.
  17. #15
    Superjim's Avatar
    Superjim is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: '06 DTS Performance Sedan
    Jun 2006
    Ft. Worth
    65
    1,852
    Re: Whitewall tires
    That is a beautiful automobile.
    I really like the whitewalls and the wheels.
    Texas Jim
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
