Thread: Speaker Grill On Door Cracked
- 01-30-10 07:35 PM #1
Cadillac(s) I Drive: 2008 dts
- Join Date
- Oct 2009
- Age
- 53
- Posts
- 4
I have a 2008 DTS and the speaker grill on the right, rear passenger door is cracked. I ordered a new one from GM but I can't figure out how to get the old one off. Any help or direction would be apprecitated.-thanks!
Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.- Join Date
- Always
- Age
- 2010
- Posts
- Many
- 01-30-10 11:41 PM #2
Re: Speaker Grill On Door Cracked
- 01-31-10 08:15 PM #3
- Join Date
- Oct 2009
- Age
- 53
- Posts
- 4
My daughter accidentally kicked it when getting out of the car. Not sure if that would be covered. I already ordered the part from GM. Hopefully I can figure it out when I get the new part.-Thanks
- 02-12-10 09:39 PM #4
Cadillac(s) I Drive: Sedan de Ville, CTS
- Join Date
- Mar 2007
- Location
- San Antonio, Tx
- Posts
- 4,573
Go to any body shop. They will assist you. Take your daughter with you. Have her explain to the body shop guy that her dad is going to "draw and quarter" her unless she gets it fixed. He will fix it with a smile.
- 02-14-10 11:30 AM #5
- Join Date
- Jan 2005
- Posts
- 52
From another posting on net if it helps, not sure I can post a source here???
"I think the inside door handle bezel has a screw behind it.
There are push in retainers around the outer perimeter of the panel and two metal clips in the center that can't be pulled out but have to be lifted.
It is tricky because you have to disengage all the surrounding clips, then hold the outer edges away from the door and lift straight up.
There are a few nuts that secure the grille to the panel".
HTH
- 02-14-10 04:20 PM #6
- 02-14-10 10:43 PM #7
- Join Date
- Mar 2007
- Location
- San Antonio, Tx
- Posts
- 4,573
- 02-15-10 09:48 AM #8
- Join Date
- Oct 2009
- Age
- 53
- Posts
- 4
Thanks B8TZM. I just received the speaker cover. I am going to give it a try.
| Sponsored Cadillac Advertisements (Supporting Members don't see these ads): | |
LinkBack URL
About LinkBacks
