TSB For Flickering Headlights - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Like Tree3Likes
Cadillac DTS Forum - 2006 through 2012 Discussion, TSB For Flickering Headlights in Past Cadillac Vehicle Discussion; Originally Posted by billdaman http://www.cadillacforums.com/forums...nightmare.html Replacing the bulbs sounds worse than it is. Took me about an hour. Seems easiest ...
  1. #16
    bigtone's Avatar
    bigtone is online now Cadillac Owners Enthusiast
    Automobile(s): 2010 DTS, 2006 DTS, 2001 Deville,
    Jun 2003
    567
    Re: TSB For Flickering Headlights
    Replacing the bulbs sounds worse than it is. Took me about an hour. Seems easiest to to one side at a time, in other words do not remove the entire front valance from the car.
  2. #17
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    684
    bigtone could explain just a little how to do one at a time, ( can the whole lens be removed doing one side at a time? ). Would you be able to take the lens inside you're home and change all bulbs you're way? Sorry if the questions sound silly but I've never had to replace mine yet, just being informed and ready when I have to thanks.
  3. #18
    brucehammond is offline Cadillac Owners Member
    Automobile(s): 2006 DTS, 2013 ATS 2.5
    Nov 2012
    57
    60
    Quote Originally Posted by Tom's Caddy
    It really is not that bad. I did it without even taking the wheel off I actually had to take the passenger side off twice to change the ballast. Had it in and out in 37 minutes.
  5. #19
    bigtone's Avatar
    Jun 2003
    567
    Quote Originally Posted by Tom's Caddy View Post
    If you just loosen one side of the valance, you do not need help removing it entirely off the car. There is enough flex in it to pull it away the 6 inches or so that you need to remove the light assembly itself. If I remember, after valence is out of the way, 3 bolts (all 10mm) is all that holds the light assembly in. I did not remove the wheel either. There is a good writeup with pics that helped me as far as finding the bolts by feel. Do a search.
  6. #20
    bearwax is offline Cadillac Owners Member
    Aug 2012
    1
    My right HID headlamps on my 2006 DTS has started turning off randomly. sometimes it will flicker a couple times and stay off. If I manually turn off the headlamps and then back on, it will usually stay on again for awhile. Some nights it will stay on without flickering. The headlamp is still bright, but definitely has a pink tint to it. It's not visibly flickering more than a couple times.
    I've read online about bulbs and ballasts and from what it seems like to me, is that it's time to replace the bulb, but if I wait longer the bulb flickering could get worse and cause the ballast to fail. Does that seem like a fair assessment? The ballast is awfully expensive and I'm hoping that if I replace the bulb now, while it's just starting to go out, that maybe that will save the ballast. Can anyone offer some advise?
    Do the front wheels need to come off, or can they be turned out of the way? This determines whether I can do the job myself. I don't have a jack and don't want to buy one.
    Blackie06 and Cadillacman916 like this.
  7. #21
    Jul 2012
    Ontario, Canada
    684
    The wheels do NOT have to come off. Just change the bulb, once you have done this it is much faster the second time if you need to do the ballast later. When you see your ballast see if it is made in France or Germany. Mine is made in Germany, I think I read on a thread that the 2006,2007 have the French and 2008 and up have the German and they are trouble free.
  8. #22
    tonnywhite62 is offline Cadillac Owners Member
    Dec 2014
    55
    1
    hello, I just brought new HID Bulbs for my 2006 DTS. I took the bumper off and pull the head light assembly out just to find out the bulb cover has tamper proof screws on it. do anyone know what size T??
  9. #23
    thellmer is offline Cadillac Owners Member
    Dec 2014
    Brooklyn, NY
    83
    It's a standard Torx T15
  10. #24
    Nov 2012
    57
    60
    Just take a pair of needle nose pliers and break off the tamper proof studs. They come off easily. Then you can use a regular torx bit.
  11. #25
    WavyGravy is offline Cadillac Owners Member
    Jul 2013
    3
    Quote Originally Posted by tonnywhite62 View Post
    Wait a sec, I thought you had to take the front wheel off to get the headlight assembly out. The way you say it makes it sound like you just removed the bumper and pulled the headlight, or did you just not mention that step? Want to make sure I am not missing a shortcut to an issue that has been the biggest pain in my ass for at least the last year. Thanks.
  12. #26
    Nov 2012
    57
    60
    Turn the wheel all the way to the right to take the left headlight out. Use a bungee cord to hold the fender liner back out of the way.
  13. #27
    dodger21 is offline Cadillac Owners Member
    Jul 2013
    30
    Looking for replacement for HID ...5000k or 6000k?...looking for brand name recommendation too thanks....I keep telling myself I can this on my own.
  14. #28
    danog is online now Cadillac Owners Fanatic
    Automobile(s): 1936 cadillac 08 DTS 11 DTS
    Nov 2011
    455
    FYI
    80% of "Philips" bulbs in the aftermarket are counterfeits / fakes
    Buyer beware.With rare exception, 80% or more of the "Philips" bulbs listings for new bulbs on eBay, Amazon and other locations are fake, Counterfeit look alike bulbs made in China. The Chinese have done a very "good" job to closely duplicate the labeling and the construction of the real Philips HID bulbs when making the fakes. 99.9% of people cannot tell the difference, in terms of appearance. We have purchased some of the fakes and will soon add some photos (High Resolution), comparing real with fakes. We will show you what to look for. This will help you determine that you are buying the real thing. This comparison will help all buyers and sellers to know what is a real Philips bulb. If we did not know what to look for we could be fooled too, the fakes are that "good" in appearance. HID bulbs claiming to be Philips and they come from China or some broker in USA (marked made in Germany), they are fakes. Likely some do not know that they are really selling fakes.
    There are at least 2 companies in China making these fakes. We have been approached by them to switch over and greatly change our profit levels. The Chinese copied Philips can be purchased labeled as D2S 85122, 85122+, 85122 CM and 85122 WX, also D2R 85126, 85126+, 85126 CM and 85126 WX, All of these fake bulbs can be purchased from China for about $8.00 each (in quantity) with a very good (tempting) profit margin. They are also making fake D1S, D1R, D3S, D3R, D4S and D4R bulbs as well and offering them for less than $10 each.
    So far we have not seen any copies of the Philips DL50/740 The market for them is so small I doubt the Chinese would bother to even copy the labeling for this model.
    A true 6000K Ultinon bulb from Philips will always have red colored salts in the arc chamber not yellow colored salts. Wholesale (not retail) from Philips the Ultinon is about $80.00 for 1 bulb. If you are paying less than $90.00 plus shipping for 1 Philips 6000K bulb it is most likely fake or used. Also, the ceramic tube will be blueish purple colored not brown or other colors. We do not sell any of the higher color temperature bulbs including 6000K Philips Ultinon (they are not DOT legal to use in USA) so you will need to look for another seller for those.
    We only offer the standard Philips 85122 and 85126 4200/4300K color (yellow colored salts), These are the standard bulbs the car typically comes with from the car factories.
    We purchase our bulbs directly from Philips USA. In the last 6 months we have seen a significant increase of the fake Philips copies coming from China, land of the fakes. Fair competition is fine, but this is not ok. We and the customer are the losers in this. The fakes are being sold in many cases for more than the real bulbs. In most cases the prices are about the same, real or fake. The fake bulbs will not have the same life (2000 - 3000 hours+) as real Philips bulbs. Chinese HID bulbs typically last 500-1000 hours and frequently much less. This is NOT a good deal for the buyer. They will damage your plastic headlight lenses and reflectors inside. UV light will yellow clear lenses over time. The fake bulbs do not have good UV (ultraviolet) light filtration by the outer glass tube on the bulb. Philips uses high quality UV stop quartz glass. You the customers should be upset about this and make sure you are getting what you were promised and paid for.
    In many or even most of the fakes, the arc chamber (where the light comes from) is off position front to back on the bulb length axis. This means the light beam from your headlight will not be accurate compared to an OEM authentic bulb. From the many samples of fakes we got recently, some of them were off by as much as 2 or more millimeters. 1/2 were off by at least 1 mm. Even 1 mm is a lot in this technology. For this reason alone, all of these bulbs would be considered rejects by Philips and destroyed. Philips bulbs are made with very tight computer controlled tolerances (precision). Each one is optically tested at the factory to be within very tight optical specs and others.
    We know the origins of our bulbs so we know 100% they are real there are no 3rd party brokers involved in our Philips bulb purchases. We also have ethics and would never knowingly sell fakes as real. We get our invoices from Philips USA. Because we buy bulk in trays we do not have Philips individual bulb boxes, we do our own single packaging.
    Philips Introduces New Anti-Counterfeit Xenon HID Packaging
    Press release date: August 27, 2014
    Advertisement
    - Certificate of Authenticity protects customers from counterfeit Philips Xenon lighting -
    Farmington Hills, MI – Philips Automotive North America, a division of Royal Philips (NYSE:PHG), has developed special packaging to prevent piracy and protect customers from buying counterfeit Philips Xenon HID lighting. The new packaging design was announced by Ann-Marie Hines, Senior Marketing Manager at Philips Automotive. Philips undertook the initiative because of the proliferation of counterfeit Philips Xenon HID lighting in the market.
    The new Philips packaging design employs a unique, state-of-the-art anti-counterfeit technology to ensure that customers are getting a genuine Philips product. Every Philips Xenon HID lighting package incorporates the Philips ‘Certificate of Authenticity,’ which features a security code and other special security elements that can be used to verify authenticity. To make sure they have a legitimate Philips Xenon HID lighting product, retailers, service professionals, and consumers alike can either scan the QR code or go to www.philips.com/original and check the security code.
    In making the announcement, Hines noted, “It is very important for us to protect our customers and our end-consumers, as well as our Xenon HID lighting brand. Philips is the inventor and world leader in Xenon HID lighting. We employ innovative technology, advanced materials, high-quality production and rigorous testing to ensure the performance and the quality of our Xenon HID products. These counterfeits are inferior to the true Philips design in both quality and performance. Furthermore, they are illegal to sell, purchase, or possess.”
    For more information about Philips Anti-Counterfeit Packaging, visit www.philips.com/original or call 1-800-257-6054.
    About Philips Automotive
    From high performance lighting that improves driver safety, to lighting designed to enhance the style of your ride, Philips offers automotive lighting that will help you make the most of your driving experience. All Philips Automotive products incorporate the leading edge lighting technology and original equipment quality that have made us the first choice of car manufacturers around the world.
    About Royal Philips
    Royal Philips (NYSE: PHG, AEX: PHIA) is a diversified health and well-being company, focused on improving people’s lives through meaningful innovation in the areas of Healthcare, Consumer Lifestyle and Lighting. Headquartered in the Netherlands, Philips posted 2013 sales of EUR 23.3 billion and employs approximately 116,000 employees with sales and services in more than 100 countries. The company is a leader in cardiac care, acute care and home healthcare, energy efficient lighting solutions and new lighting applications, as well as male shaving and grooming, home and portable entertainment, and oral healthcare. News from Philips is located at www.philips.com/newscenter.
    Media Contact:
    Ann-Marie Hines
    Sr. Marketing Manager Philips Automotive, NA
    34119 W. 12 Mile Rd.
    Farmington Hills, MI 48331
    Tel: (248) 957-4085
    Email: ann-marie.hines@philips.com
  15. #29
    Cadillactica's Avatar
    Cadillactica is offline Cadillac Owners Member
    Automobile(s): 2007 DTS
    Feb 2015
    20
    I am dealing with this dreaded issue. My drivers side light went out causing me to receive several work orders (from police) to resolve this issue but never could track down the problem. I've had the light replaced as well as fuses to no avail. I didn't press the issue because I was able to have the work order signed off on, the passenger side light was still working along with my fog lights but now that both lights have gone out I have no choice but to take care of this ASAP.
    I will order ballast along with headlights, is there anything else that I need to purchase? I see ballast range from 80 to 100 dollars on ebay. Is there anything specific I should be looking for to ensure I am purchasing the correct parts. I will attempt to tackle this myself since everything I have read indicates labor will be 1k or more. What tools do I need to have in order to complete the job? Please PM me if you have any info regarding this issue Any help and or/advice will be very much appreciated.
  16. #30
    Feb 2015
    20
    I'm looking to purchase a set of ballast. How do I know what type of ballast I need for my vehicle? I have a 2007 Cadillac DTS, I'm seeing it may be 2 different models for this vehicle. I have not removed anything on the vehicle to check. I do not want to do this until I actually set to do the work.
  17. Remove Advertisements
