Had a new self-correcting "bug" occur over the weekend. Had a warning come up on the driver info center that said, "Service Tire Pressure Monitor" or something like that. I had just hit a pretty sharp bump in the road with all four tires at 45-50MPH. I cycled through the options in the driver info center to view my tire pressure and noticed where you normally see "Rear Left 35 PSI" or similar, it said "Rear Left --". The proper tire pressure registered for all of the other three tires. I stopped to be sure the left rear wasn't going flat (did I mention I had hit a fairly SHARP bump?").
Left rear looked okay. I turned off the car and started it back up since this seems to sometimes mitigate some of the electronic bugs that I had early in the life of this 2006 Lux II. (just like any other computer)
Left rear still didn't register. I arrived at my destination last night and parked. Got up this morning and that left rear monitor was working fine. Go figure. (Maybe that big bad bump hut it's wittle feewings, but now it's all better).
By the way, do those individual stem mounted monitors ever require battery replacment? I assume they require some sort of power source to transmit the signal to the vehicle info center. (I drive my cars a long time)
