'91 DeVille - trans problems?
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, '91 DeVille - trans problems? in Past Cadillac Vehicle Discussion; when i am cruising(doesn't matter how fast), and give it a little gas....i get a really bad 'shimmy'...sort of like ...
    delvryboy's Avatar
    delvryboy is offline Cadillac Owners Member
    Dec 2003
    The Windy
    20
    when i am cruising(doesn't matter how fast), and give it a little gas....i get a really bad 'shimmy'...sort of like going over ripples in the road
    also, when i hit around 70-75mph, i get the same thing...burrap, burrap, burrap
    if i get on it or let off the gas, the vibration goes away
    could it be a trans problem?...it has 110k on it
    inmycadillac's Avatar
    inmycadillac is offline Cadillac Owners Enthusiast
    Automobile(s): 06 DTS Luxury II-?, 98 Eldorado-Crimson Pearl
    Jan 2004
    North Dakota
    39
    511
    ExclamationRe: '91 DeVille - trans problems?
    Quote Originally Posted by delvryboy
    Try pulling your codes, hold "off" and "warmer" buttons at same time until display goes nuts, do this with the car off but key in start postion, then look at fuel display and watch what codes come up, write them down and post them herre. If u get code E39, u might have a problem.
    It could be bad rear shocks, though. I'm not sure what u mean by the "burap" sound. Let us know. Whatever u do, don't take it to a transmission shop!
    RBraczyk's Avatar
    RBraczyk is offline Cadillac Owners Connoisseur
    Jan 2004
    Amherst, NH
    29
    4,178
    i had the EXACT same thing in my blazer, your tranny plates are slipping. Go look for a new transmission. But first, open the tranny pan first, if its full of metal, get a new one.
    delvryboy's Avatar
    Dec 2003
    The Windy
    20
    the only code i have is the stinking 85 i cannot get rid of...i think i am going to replace the TPS(last resort, not in flow chart) just as a shot in the dark
    my first thoughts are a mechanical trans problem
    ...but, it seems to have some irratic shifting, when i give it a little gas, where normally it should downshift, it stays in 3rd....which will cause that shimmy
    can my e85 and irratic shifting be related?
    Jan 2004
    North Dakota
    39
    511
    I had code 85 before too. Caddy dealer showed me in his diagnostic book and it said to clean the throttle body. So I did clean throttle body and that took care of it! Sounds like your tranny is pooping out on ya. I don't know too much about trannys but if its slipping, I know thats BAD.
    RBraczyk's Avatar
    Jan 2004
    Amherst, NH
    29
    4,178
    your transmission is eating shitt right now.
    Cadillac-Junkie's Avatar
    Cadillac-Junkie is offline Cadillac Owners Member
    Mar 2004
    EVERETT MASS
    50
    82
    i have a code po=85 says idle throtle angle is to high. does it just need to be cleaned or is there a adjustment needed to be made and where is it located? thanks
    90devilleguy's Avatar
    90devilleguy is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS-V & 1962 Coupe Deville
    Nov 2003
    Framingham,Ma
    548
    yeah that happenes on my car when it shifts from 2nd to 3rd the car will shift gears but the engine stays at the same rpms when it happens right around 2500 rpms but i notice the other day that if i slowly increase the engine speed when in park that right at 2500 rpms my engine kind of misfires or skips. check out that your engine is running smooth all the way through the rpm band, and maybe it's just time for a tune up. this week i'm getting one done if all goes well i'll let you know.
  11. Remove Advertisements
