90 deville error codes E34 and E39
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 90 deville error codes E34 and E39 in Past Cadillac Vehicle Discussion; what would cause these to occur? my service engine soon appeared, when i turned the car off and on again ...
    nannerz's Avatar
    nannerz is offline Cadillac Owners Member
    Feb 2004
    Ontario, California
    18
    Question90 deville error codes E34 and E39
    what would cause these to occur? my service engine soon appeared, when i turned the car off and on again it was gone but did show again about 5 min. after driving. my manual shows 34 as MAP sensor signal out of range and 39 as VCC engagement problem, what is VCC? can not seem to find it in my book. thanks
    inmycadillac's Avatar
    inmycadillac is offline Cadillac Owners Enthusiast
    Automobile(s): 06 DTS Luxury II-?, 98 Eldorado-Crimson Pearl
    Jan 2004
    North Dakota
    40
    511
    ExclamationRe: 90 deville error codes E34 and E39
    Quote Originally Posted by nannerz
    VCC is transmission related. It stands tor torque converter clutch engagement. I have the exact same problem. Haven't fixed it yet. If u want more info go to my post here about "code 39". There is some good replies there.
    Cadillac-Junkie's Avatar
    Cadillac-Junkie is offline Cadillac Owners Member
    Mar 2004
    EVERETT MASS
    50
    82
    94 deville can u tell me how to go about fixing the po-85 code which is the idle throttle angle is to high>>
