| 1991 DeVille 4.9 - Speedometer/Transmission problems, help! Hello, I hope someone can help me out here.
The Car - 1991 SDV 4.9L FWD
The problem - About a month ago, I noticed a strange thing happening, sometimes, when I was stopped and then lightly touched the gas pedal, the speedometer would drop itself down to 0, stay there for a couple seconds and then wave its way back to my current speed. Durring the time the speedometer was at 0mph, the car would rev higher than normal. After the speedometer went back to the current speed, the transmission would shift up a gear, and the revs would come back down.
Recently however, the speedometer has stopped working all together, and stays at a constant 0, and the transmission is now not shifting past second gear, and the service engine light is on.
I've read some similar situations, however I haven't found anything leading to the exact problem. If needed, I can get the OBD codes from the computer.
Anybody have any ideas?
Update, here's the OBD codes the computer gave me. P024 (E024) ..................................... Vehicle Speed Sensor signal to TCC
P052 (E052) .................................................. ..... PCM Memory Reset
P055 (E055) ............................... Closed Throttle Angle Out of Range [TPS]
P064 (E064) ................................. Cruise - Vehicle Acceleration Too High
P073 (E073) ..................................... Intermittent Coolant Sensor Signal
P075 (E075) ................................................ Intermittent VSS Signal
I'm hoping that the speed sensor is the one near the wheel that's easy to fix, and not in the transmission, anyone know?
Reason: Update
