Results 1 to 9 of 9
Thread: moving the battery to the trunk
    Jan 2003
    Okinawa japan
    32
    1,623
    i wana move the battery to the trunk, its in the way of my cone filter idea, and i'd rahter have like 10lbs in the trunk insted of up front, that V8 is enough wieght up there. So what all do i need to get/do?
    Jan 2003
    nearPhillyPA
    64
    Try summitracing.com or jegs.com for a battery relocation kit.
    Jan 2003
    Okinawa japan
    32
    1,623
    cool, thanks. 42 bucks isnt that bad.
  5. #4
    Mad'lac's Avatar
    Mad'lac is offline Cadillac Owners Connoisseur
    Automobile(s): 1984 Fleetwood Brougham coupe
    Dec 2002
    Floresville, Texas
    42
    1,576
    Maybe now would be a perfect time to put in a Optima battery. I heard that even if they crack they don't leak. Might be nice to have that in the trunk.
  6. #5
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Good idea with that Optima.. What IS the weight ratio on these cars? I mean from front to back?
  7. #6
    Jan 2003
    Okinawa japan
    32
    1,623
    thats a good question, one that i really wana know. And how muc do those optima batteries go for?
  8. #7
    Jan 2003
    Tampa, FL
    36
    266
    Optima, roughly $100. Educated guess 57/43 weight bias. Word of advise. Make sure the wire runing off the altanator to the positive post of the battery is at least 10 gaw wire. I had a charging problem with my 85 FW when I did that mod. If you buy the kit from Jegs you should be ok. I built mine from scratch so I had problems. Live and learn I guess.
  9. #8
    Andrew60SP's Avatar
    Andrew60SP is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special
    Jan 2003
    Vancouver, Canada
    303
    A search turned up the following:
    current model STS: 62/38
    DTS: 61/39.
    CTS: 52/48
    '67 Eldorado: 58/42
    I would imagine most FWD Caddy's being at least 60/40.
  10. #9
    Jan 2003
    Newtown, PA
    58
    6,472
    Hey Shaun,
    Good to see you here
    The Optima is a great battery for specific applications. Also remember that the Optima can be mounted in any orientation (sideways, on-end, etc.). Also, cable routing is CRITICAL for safety as well as durability.
  • You may not post replies
