Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: 98 deville cranks will not start reads theft system problems car may not restart
09-02-06, 08:37 PM
| | Cadillac Owners Member Cadillac(s): Cadillac 1998 deville | | Join Date: Aug 2006 Location: delaware | | | 98 deville cranks will not start reads theft system problems car may not restart started car with remote. got in car hit the brake car shut off.now the car cranks but will not start. has fire and good fuel pressure.car starts for a seccond or two with starting fluid.dash reads theft system problems car may not restart. need help!!!!!  |
09-13-06, 08:35 PM
| | Cadillac Owners Member Cadillac(s): Cadillac 1998 deville | | Join Date: Aug 2006 Location: delaware | | | Re: 98 deville cranks will not start reads theft system problems car may not restart Ha guys caddy is dead the water need help!  |
09-14-06, 01:27 AM
| | Cadillac Owners Enthusiast Cadillac(s): 1998 Cadillac Deville Sedan | | Join Date: Feb 2005 Location: Stevens Point, WI Age: 26 | | | Re: 98 deville cranks will not start reads theft system problems car may not restart Did it happen after you had the remote start put in? Ask the guy who installed the remote starter, maybe it's interfering with the factory security/computer system.
The theft system is what's keeping ur engine from starting, but I'm not even novice on that subject... |
09-14-06, 07:47 AM
|  | Cadillac Owners Member Cadillac(s): 94 Eldo 155k | | Join Date: Jun 2005 Location: Rochester,NY Age: 36 | | | Re: 98 deville cranks will not start reads theft system problems car may not restart i had a prob like this 1'ce.....but it was dirt on the key and in the ignition...
try cleaning the tumblers and the key with eather.....hope its sometin that eazy 4 ya gl |
09-14-06, 08:57 AM
| | Cadillac Owners Enthusiast | | | | | Re: 98 deville cranks will not start reads theft system problems car may not restart Likely the resister pellet in the key has been bypassed to allow an aftermarket starter to be installled. Otherwise, the system would not even crank unless VATS was bypassed.
You're going to have a hard time getting an answer here I suspect because no one knows how the aftermarket starter was installed and how the VATS was bypassed to get the aftermarket starter to work.....
As soon as you put the aftermarket electronics on the car all bets are off, unfortunately.... |
09-14-06, 08:48 PM
| | Cadillac Owners Member Cadillac(s): Cadillac 1998 deville | | Join Date: Aug 2006 Location: delaware | | | Re: 98 deville cranks will not start reads theft system problems car may not restart i took the remote starter off the car ,still will not start.have codes of B2719 and B2750 |
09-14-06, 09:00 PM
| | Cadillac Owners Member Cadillac(s): 65 CDV vert, 02 STS, 92 Eldorado, 96 fleetwood | | Join Date: Sep 2006 Location: west Coast Age: 34 | | | Re: 98 deville cranks will not start reads theft system problems car may not restart try reprogramming, put key in , turn to on position for ten minutes,turn off leaving key in switch for 5 seconds, turn on for another 10 minutes, off for 5 sec, on again for ten minutes and it should start |
09-15-06, 07:24 PM
| | Cadillac Owners Member Cadillac(s): Cadillac 1998 deville | | Join Date: Aug 2006 Location: delaware | | | Re: 98 deville cranks will not start reads theft system problems car may not restart try that two or three times. didn't work. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
