Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Northstar Head Gasket Issue Corrected
08-07-06, 11:51 AM
| | Cadillac Owners Member | | | | | Northstar Head Gasket Issue Corrected HI Guys,
Just wanted to know if any one out there as any documentation as to when the head gasket issue on the northstar was corrected by Cadillac. What year models have the revised Northstar engine where overheating and blown head gaskets won't be a problem. I was specifically looking for a DeVille model, but want to avoid buying a Northstar engine that might overheat. Any advice or docs are greatlty appreciated.
Thanks, |
08-07-06, 01:27 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Northstar Head Gasket Issue Corrected Head gaskets can be a problem on any aluminum engine. Proper cooling system maintanence it the best provention, though not a guarantee. I sold my '97 with 107K and never had a problem. Many here have much higher milage with no problems. Once in a while lightening strikes a low milage car. Shit happens. That said, I think it was 2000 that several changes where made to the Northstar, one of which was longer head bolts and a different thread pitch to strengthen the clamping force. |
08-07-06, 02:37 PM
| | Cadillac Owners Member | | | | | Re: Northstar Head Gasket Issue Corrected Thanks Ranger |
08-07-06, 05:05 PM
| | Cadillac Owners Member | | | | | Re: Northstar Head Gasket Issue Corrected I have a 2000 with a 100,000 miles with no issues. |
08-07-06, 06:24 PM
|  | Cadillac Owners Master Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS | | Join Date: Apr 2005 Location: Upstate NY | | | Re: Northstar Head Gasket Issue Corrected I don't think the issue as a whole was ever 'fixed' so to speak. It's my understanding that post 2000 there were some changed made to the angle of the head bolts or thread pitch or something and some oil leak issues were addressed.
I would say don't buy pre 2000 stay with 2000 and newer.
Yes coolant maintenance is the best preventative maintenance. |
11-15-06, 04:59 PM
|  | Cadillac Owners Member Cadillac(s): Seville STS 1999 | | Join Date: Nov 2005 Location: Germany - Bavarian | | | Re: Northstar Head Gasket Issue Corrected Campaign - Cylinder Head Bolt Hole Counterbore
Customer Satisfaction - Engine Block Cylinder Head Bolt Thread Holes-Deep Counterbore # 99086 - (Mar 19, 2002)
Models:
Certain 1999 Oldsmobile Aurora Model Vehicle
Equipped with 4.0L Engine (RPO L47-VIN Code C)
Certain 1999 Cadillac Seville, DeVille and Eldorado Model Vehicles
Equipped with 4.6L Engine (RPO LD8-VIN Code Y or RPO L37-VIN Code 9)
THIS CAMPAIGN BULLETIN ADDRESSES VEHICLES IN DEALER INVENTORY AND VEHICLES DELIVERED TO CUSTOMERS. VEHICLES THAT PASS THE INSPECTION PROCEDURE WILL BE RELEASED FROM THE STOP DELIVERY ISSUED SEPTEMBER 13, 1999 VIA DCS MESSAGE WIS19990023 AND WIS19990024. DEALER INVENTORY VEHICLES THAT DO NOT PASS THE INSPECTION ARE NOT TO BE DELIVERED TO CUSTOMERS BUT ARE NOT TO BE RETURNED TO GENERAL MOTORS. CUSTOMER VEHICLES THAT DO NOT PASS THE INSPECTION HAVE SPECIAL INSTRUCTIONS. REFER TO THE SERVICE PROCEDURE FOR DETAILS.
Important: Cadillac customers involved in this campaign will be notified by GM beginning December 17, 1999. Oldsmobile Aurora customers involved in this campaign will be notified by GM at a later date when 4.0L engines become available.
General Motors has decided that certain 1999 Oldsmobile Aurora model vehicles, equipped with 4.0L engine (RPO L47, VIN C) and Cadillac Seville, DeVille and Eldorado model vehicles equipped with 4.6L engine (RPO LD8, VIN 9 or RPO L37 VIN Y) may exhibit a condition in which they cylinder head bolts may become loose and cause coolant leaks and possible engine damage. This may be due to the engine block cylinder head bolt counterbore holes being machined too deeply into the engine block.
To prevent the possibility of this condition occurring, dealers are to inspect vehicles held under the above referenced stop delivery and those delivered to customers. Depending on the findings, the engine may not require any further repairs, may require replacement or the vehicle may need to be returned to GM.
Vehicles Involved
Involved are certain 1999 Oldsmobile Aurora model vehicles equipped with 4.0L engine (RPO L47, VIN C) and Cadillac Seville, DeVille and Eldorado model vehicles equipped with 4.6L engine (RPO LD8, VIN Y and RPO L37, VIN 9), and built within the VIN breakpoints shown
Important: Dealers should confirm vehicle eligibility through VISS (Vehicle Information Service System) prior to beginning campaign repairs. Information for Oldsmobile Auroras delivered to customer will be loaded in VISS at a later date when 4.0L engines are available and Oldsmobile owner letters are mailed. [Not all vehicles within the above breakpoints may be involved]
Involved vehicles have been identified by Vehicle Identification Number. Computer listings containing the complete Vehicle Identification Number, customer name and address data have been prepared, and are being furnished to involved dealers with the campaign bulletin. The customer name and address data furnished will enable dealers to follow-up with customers involved in this campaign. Any dealer not receiving a computer listing with the campaign bulletin has no involved vehicles currently assigned.
These dealer listings may contain customer names and addresses obtained from State Motor Vehicle Registration Records. The use of such motor vehicle registration data for any other purpose is a violation of law in several states. Accordingly, you are urged to limit the use of this listing to the follow-up necessary to complete this campaign.
Parts Information
Parts required to complete this campaign are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" prior to ordering requirements. Normal orders should be placed on a DRO = Daily Replenishment Order. An emergency requirement should be ordered on a CSO = Customer Special Order.
Important: Due to the small number of vehicles involved, dealers are encouraged not to order campaign parts for use as shelf stock. Parts should only be ordered when inspection determines that it is necessary to replace the engine.
Customer Notification
Customers will be notified of this campaign on their vehicles by General Motors beginning December 17, 1999. Oldsmobile Aurora customers will be notified of this campaign on their vehicles by General Motors at a later date when 4.0L engines become available. (See copy of typical customer letter shown in this bulletin -- actual divisional letter may vary slightly).
Dealer Campaign Responsibility
All unsold new vehicles in dealers 'inventory and subject to this campaign MUST be held, inspected and returned to GM if this condition exists, per the service procedure of this campaign bulletin. All unsold new vehicles in dealers' inventory and subject to this campaign MUST be held, inspected and may be released from the "Stop Delivery" order BEFORE customers take possession of these vehicles if this condition does not exist, per the service procedure of this campaign bulletin.
Cadillac customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Oldsmobile customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is not customer information indicated on the dealer listing, are not to be contacted by the dealer until the Oldsmobile customer letter and Olds Aurora dealer listing are mailed at a later date. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. This could be done by mailing to such customers a copy of the customer letter shown in this bulletin. Campaign follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this campaign enters your vehicle inventory, or is in your dealership for service in the future, please take the steps necessary to be sure the campaign correction has been made before selling or releasing the vehicle.
Campaign Identification Label
Each vehicle corrected in accordance with the instructions outlined in this Product Campaign Bulletin will require a "Campaign Identification Label". Each label provides a space to include the campaign number and the five (5) digit dealer code of the dealer performing the campaign service. This information may be inserted with a typewriter or a ball point pen.
Each "Campaign Identification Label" is to be located on the radiator core support in an area which will be visible when the vehicle is brought in by the customer for periodic servicing. When installing the Campaign Identification Label, be sure to pull the tab to allow the adhesion of the clear protective covering. Additional Campaign Identification Labels can be obtained from Dealer Support Materials by calling 1-888-414-6322 (Monday-Friday, 8:00 am to 5:00 pm EST). Ask for Item Number 5-1015 when ordering.
Apply the "Campaign Identification Label" only on a clean, dry surface.
Submit a Product Campaign Claim with the information shown.
Refer to the General Motors Corporation Claims Processing Manual for details on Product Campaign Claim Submission. |
01-16-07, 05:42 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Northstar Head Gasket Issue Corrected I have a 2002 deville with the 4.6 northstar engine. Me and my friend (really good friend) have dropped the engine to do a head gasket replacment. I 've got the gaskets and new head bolts from the local chevy dealer. My Clilton book gives me no information on this engine. I am looking for the torgue pattern for headbolts.
please Help.
Thanks Les  |
01-16-07, 06:35 PM
| | Cadillac Owners Connoisseur Cadillac(s): 1996 Deville (sold), 2000 Mustang GT | | Join Date: Jan 2007 Location: Jersey Age: 25 | | | Re: Northstar Head Gasket Issue Corrected 96 N* with 82,000 miles just blew a head gasket. I don't think the previous owner knew that he had to maintain the cooling system though. |
01-16-07, 10:20 PM
|  | Cadillac Owners Fanatic Cadillac(s): 03 STS, 97 STS, 58 Eldo | | | | | Re: Northstar Head Gasket Issue Corrected Quote:
Originally Posted by RAMELL'S I have a 2002 deville with the 4.6 northstar engine. Me and my friend (really good friend) have dropped the engine to do a head gasket replacment. I 've got the gaskets and new head bolts from the local chevy dealer. My Clilton book gives me no information on this engine. I am looking for the torgue pattern for headbolts.
please Help.
Thanks Les  | First Pass 30 ft. lbs.
Second Pass + 70°
Third Pass + 60°
Final Pass +60°/190° Total
7 3 1 5 9
10 6 2 4 8
then the tens on the side from top to bottom 106 inch pds |
01-16-07, 10:52 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Northstar Head Gasket Issue Corrected  Before you go any further, get a FSM from Helm Inc and use the Chiltons to soak up trans fluid from the garage floor. Are you Timeserting all 20 of the head bolt holes? If you don't, you may pull threads on reassembly if you haven't on disassembly, or they are likely to fail again in 10 - 20K. |
01-16-07, 10:56 PM
Originally Posted by Ranger  Before you go any further, get a FSM from Helm Inc and use the Chiltons to soak up trans fluid from the garage floor. Are you Timeserting all 20 of the head bolt holes? If you don't, you may pull threads on reassembly if you haven't on disassembly, or they are likely to fail again in 10 - 20K. |
YA and that, thanks for saving the day once again Ranger, I assummed they knew... |
01-16-07, 10:58 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Northstar Head Gasket Issue Corrected Maybe they do, but there was no mention of it and I see disaster in their future, so I thought it was worth a mention. |
01-17-07, 12:06 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Northstar Head Gasket Issue Corrected I just received my 2001 Deville FSM in the mail yesterday; one thing that has me worried is a somewhat rough idle and a fair amount of oil leakage - I just last week rolled over 60K miles.
Has anyone ever purchased this kit? http://cgi.ebay.com/ebaymotors/NORTH...spagenameZWDVW
I'm considering buying it if it will correct my oil leak situation and prevent a catastrophic engine failure - but of course I don't want to waste my money. Any input ? |
01-17-07, 10:36 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Northstar Head Gasket Issue Corrected That kit is about the same price as the kit from http://www.timsert.com. No experience, but personally I'd stick with the inserts and installation kit from Timesert. |
01-18-07, 09:06 AM
| | Cadillac Owners Connoisseur Cadillac(s): 94 ETC,97 STS | | Join Date: Sep 2003 Location: Arizona | | | Re: Northstar Head Gasket Issue Corrected Ramell, look in tech tips for the head gasket repair thread. There's a lot of info in it.
Logikal, no one on the board has used that kit. If you use it let us know how it works. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
