Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Are the analog and digital dash display interchangeable?
06-30-06, 02:06 AM
| | Cadillac Owners Enthusiast Cadillac(s): 1998 Cadillac Deville Sedan | | Join Date: Feb 2005 Location: Stevens Point, WI Age: 26 | | | Are the analog and digital dash display interchangeable? I found a 97(?) Deville Concours of the same body/interior type in a wrecking yard and it has the analog style display, I'm wondering if I can swap that in my car and still fit/works just fine?
I also found a 2001 SLS that has a wood steering wheel, can I swap mine with it? |
06-30-06, 04:03 AM
| | Cadillac Owners Fanatic | | | | | Re: Are the analog and digital dash display interchangeable? im sure it might be possible, but i seriously doubt it. it would be awesome though...id love to have a 99 concourse with digital cluster and wood wheel...for that matter, seville with all digital would be awesome too. |
06-30-06, 11:54 AM
|  | Cadillac Owners Master Cadillac(s): Jeep: '05 TJ Sport 6spd BMW: '90 325iC & '92 318iC both 5spd | | Join Date: Mar 2003 Location: Middle Georgia Age: 22 | | | Re: Are the analog and digital dash display interchangeable? '99 Concourse HAS analog gauges.
Heres the deal... the '97 BASE DeVille is using the dash from the '92-'95 Seville/Eldo... so... the gauge cluster from a N* powered '92-'95 Seville/Eldo will physically fit, and probably hook up.... but, the difference is the computer.... '96 switched to OBDII, The '92-'95 analog cluster ended life in..... '95.... I don't know if it will communicate with the OBDII system, tho it is possible, you would have to give it a shot. |
06-30-06, 01:42 PM
| | Cadillac Owners Enthusiast Cadillac(s): 1998 Cadillac Deville Sedan | | Join Date: Feb 2005 Location: Stevens Point, WI Age: 26 | | | Re: Are the analog and digital dash display interchangeable? Ya I wasn't sure if it was a 97, 98 or 99, all I know is it has the shifter in the center console and the interior looks just like mine...or so I rememberd.
Well how about the woodgrain steering wheel of a 2001 SLS? I don't know if Cadillac changed their steering wheel bolt pattern but they look pretty much the same. |
06-30-06, 02:50 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1988 SDV; 1997 SDV D'Elegance | | Join Date: Aug 2003 Location: Ontario Canada | | | Re: Are the analog and digital dash display interchangeable? yes, Weister, the wood wheel will fit. i have a '97 SDV with a 2003 Eldo wood/leather steering wheel and all the paddles work - straight swap. see attached photo
07-01-06, 05:44 AM
| | Cadillac Owners Fanatic | | | | | Re: Are the analog and digital dash display interchangeable? nice Frost  i have the same color interior and those wood grain accents really set it off...where did you get those? |
07-01-06, 02:11 PM
|  | Super Moderator Cadillac(s): Poor man's STS--> '00 Regal GS. | | Join Date: Dec 2004 Location: Twin Cities, MN Age: 22 | | | Re: Are the analog and digital dash display interchangeable? Quote: |
Originally Posted by mrlacy im sure it might be possible, but i seriously doubt it. it would be awesome though...id love to have a 99 concourse with digital cluster and wood wheel...for that matter, seville with all digital would be awesome too. | Just out of curiosity, why would you want the digital dash in your Concours? |
02-23-08, 03:47 PM
| | Cadillac Owners Member Cadillac(s): 97 Cadillac deville | | Join Date: Dec 2007 Location: Kentucky | | | Re: Are the analog and digital dash display interchangeable? Digital is nicer to me. In some ways that is. I like analog gas gauge though. Okay my question is i have a 97 caddy deville with digital cluster and it looks like it has been cracked and some messed up numbers i cant tell how many miles my car has. So i fount another digital cluster same 97 caddy deville from ebay looks just fine if not better i wonder if i can change it without haveing it reprogrammed, it came off of a 97 caddy with 67.000 miles and mine has about 98,000. I also would like to know how to take my dash board out so i can change it and see for myself. I found the screws under the defrost vent but after that i have no idea what to do. Any diagrams would be nice. Any idea? Thanks |
02-23-08, 03:59 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Are the analog and digital dash display interchangeable? WRONG
a wood wheel for an ELDO ONLY will work on a 95-99 Deville
a Seville wheel while will bolt up uses a completely different bag and wheel control system it wont work
and in case you havent noticed the cluster on a base has the a/c controls on it, the cluster on a concourse with analog has the a/c controls mounted beneath the radio
neither of these swaps will work |
02-23-08, 07:34 PM
|  | Cadillac Owners Fanatic Cadillac(s): 1997 Deville Concours | | | | | Re: Are the analog and digital dash display interchangeable? I thought that the analog dash could be set up to display digital speed in the info center?
DAVE
'97 Concours |
02-23-08, 07:36 PM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: Are the analog and digital dash display interchangeable? yup
it can
i did a write up in the tech tips how | | Cadillac Discussion Tools | | |
Censor is ON | | | |
