4.5 Water Pump Question.
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 4.5 Water Pump Question. in Past Cadillac Vehicle Discussion; Hi! I'm new! Anyone know how much a water pump on a `90 FWD Fleetwood 4.5 costs? My friend says ...
    moses is offline Cadillac Owners Member
    Dec 2003
    Minnesota
    7
    Question4.5 Water Pump Question.
    Hi! I'm new!
    My friend says its an easy install.. but hes know to be a bit crazy. Is it easy? Pull the block? Any information is appreciated.
    -Moses
    Dec 2003
    Minnesota
    7
    Re: 4.5 Water Pump Question.
    Okay, well I went to Checker, and a new one was about $75, and a reman was about $35.
    tru504187211's Avatar
    tru504187211 is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 Deville; 1990 Brougham
    Aug 2003
    Milwaukee
    34
    1,519
    It shouldn't be too expensive to fix...was my thinking on this problem when I had it. I basically was forced to do this as I would not trust myself to complete the job flawlessly, and because my dad refuses to help me work on "an engine this big (4.9)".
    dooscoop32's Avatar
    dooscoop32 is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Sixty Special, 1991 Allante
    Oct 2003
    Newton, NC
    65
    136
    QuestionRe: 4.5 Water Pump Question.
    I was told by my mechanic to hope my water pump never went out on my '93 Sixty Special with the 4.9 because he said it would be an all-day job and would cost me $500!! Was he bullshitting me???? :disappoin
    Aug 2003
    Milwaukee
    34
    1,519
    Maybe it is just differences in mechanics, but I paid way under that...as in hundreds less.
    Andrew60SP's Avatar
    Andrew60SP is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special
    Jan 2003
    Vancouver, Canada
    303
    I took mine into the dealer to fix. It cost me in the $500-600Cdn.
    I wish I knew how to do this mechanics stuff.
    Dec 2003
    Minnesota
    7
    The waterpump on the 4.5, is not to deep. There are only a few things that need to be removed. The bolts surrounding it are many, and different types. I'll try to take a pic when I get home, w/ my girlfriends new digital camera.
    shigirl42 is offline Cadillac Owners Member
    Apr 2004
    3
    I have just purchased (2 days ago) a 1989 fleetwood,and today something happened and water and anti freeze went all over, I was told either it was the water pump or a cracked block!!! Does any one know if there is a way to tell? any comments or sugestions would be so appreciated!!!
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by shigirl42
    Have someone pressurize the cooling system with a coolant system pressure tester (a hand pump that attaches at the pressure cap fitting and pressurizes the system) and look for leaks....simple and easy. No reason at all to guess. You can find the tool at most auto parts stores or tool rental shops or any competent repair shop or radiator shop.
    Apr 2004
    3
    Thank you!! Will that tell me if it is just the water pump or will it tell me there is a cracked block? Has any one else had this go wrong with a 89 fleetwood?
    Cadillac-Junkie's Avatar
    Cadillac-Junkie is offline Cadillac Owners Member
    Mar 2004
    EVERETT MASS
    50
    82
    i have a 4.9 and changes my waterpump remanufactured it cost me about 85 bucks without labor, and had a friend install it, it took 1 1/2 hour to get it in. good luck isnt a big ordeal.
    Apr 2004
    3
    Thank you!!! i will have a mechanic look at it tomorrow and hope for the best!!!! I will keep looking through this forum it is very intresting!!! Will let you know what happens with it!! Thanks again
  15. Remove Advertisements
