A/C and outside of car smelling like gas / varnish
Results 1 to 13 of 13
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, A/C and outside of car smelling like gas / varnish in Past Cadillac Vehicle Discussion; So i was driving today with the a/c on and i started getting this weird smell kinda like gas or ...
    CadillacCraig is offline Cadillac Owners Member
    Automobile(s): 1993 cadillac sedan deville 4.9
    Apr 2014
    phoenix, az
    26
    59
    So i was driving today with the a/c on and i started getting this weird smell kinda like gas or varnish. i got home parked in the garage and a few minutes later the whole garage had the same weird smell.
    It doesn't smell like gas out of the pump but its strong and smells horrible.
    I was doing some reading on the forum about a FPR that could go bad and cause a hard start when its warm which i had today and could cause a gas smell. Is this my problem or is it something else? All help is very appreciated.
    Just to add to the post its a 1993 sedan deville with no codes
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,369
    Re: A/C and outside of car smelling like gas / varnish
    Quote Originally Posted by CadillacCraig View Post
    can't tell from here -
    but - you could pull the vacuum supply hose off the FPR -
    and check if there is ANY gas in the hose -
    Apr 2014
    phoenix, az
    26
    59
    Do u know off hand where its located on the 4.9?
    68
    81,920
    It's a small metal canister on the fuel rail.
    You can just barely see it in the lower right of this picture next to the TB.
    Apr 2014
    phoenix, az
    26
    59
    Thank you ranger, i pulled the hose off and there was no fuel leaking from it and when i had the engine running it whistled pretty good before i put the hose back on so im gonna rule that out as the problem.
    i didnt have the smell right now either so i think its a intermittent problem, is it possibly the evap canister?
    68
    81,920
    EVAP system is a possibility.
    Apr 2014
    phoenix, az
    26
    59
    ok cool ill check it out in a little bit. if it went bad would it throw a code?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,897
    Several codes associated with EVAP - an emissions (carefully monitored) system.
    Apr 2014
    phoenix, az
    26
    59
    i wonder what it is then. i checked the hoses and there on pretty good and im not getting any codes for it so im lost.
    FrankWeld is offline Cadillac Owners Member
    Mar 2014
    5
    Same thing happens to me
    I have an 03 deville
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Thank you ranger, i pulled the hose off and there was no fuel leaking from it and when i had the engine running it whistled pretty good before i put the hose back on so im gonna rule that out as the problem. i didnt have the smell right now either so i think its a intermittent problem, is it possibly the evap canister?
    Did you check the hose, or the nipple on the FPR?
    Apr 2014
    phoenix, az
    26
    59
    i pulled the hose off on the FPR and it was dry, how do u check the nipple?
    68
    81,920
    Look at it. Put your finger on it. If it doesn't look or feel wet, it's OK.
  16. Remove Advertisements
