Fuel gauge problems - 2001 Deville
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Fuel gauge problems - 2001 Deville in Past Cadillac Vehicle Discussion; Hey guys So the fuel gauge sensor doesn't really work. It shows that it's full but it's not and sometimes ...
    Kapystin84's Avatar
    Kapystin84 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Deville
    Aug 2014
    Surrey, BC
    7
    Hey guys
    It shows that it's full but it's not and sometimes it will show that it's low on fuel when it's not at all. Please help!
    Should I get the fuel guage replaced or is their a simpler DIY method I can do at home? It's a 2001 deville
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The Gaige isn't the problem, it's the fuel level sending unit in the tank. There's an access panel in the trunk, so replacement isn't too bad.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,877
    Re: Fuel gauge problems - 2001 Deville
    Plenty of threads on this in Tech Tips. Replace the entire fuel pump module - the fuel pump is next anyway. Your car has an access hatch in the trunk floor, just forward of the spare tire well. A wiring connector, two quick connects, and a lock ring. Don't make sparks by banging on the lock ring.
    How-to video in the Airtex pump pictures in www.rockauto.com. Airtex, AC Delco, UltraPower and DELPHI are all OEM assemblies. One or two may come with a new HD electrical connector that is spliced into the existing body harness.
    Kapystin84's Avatar
    Aug 2014
    Surrey, BC
    7
    Awesome! Thanks guys
    Is there a thread on how to change the fuel level sensor yourself?
    68
    81,914
    Check the Tech Tips section. If there is one, that's where it should be.
    Feb 2006
    55,877
    Replace the entire pump module, not just the level sensor. You'll be glad you did when the fuel pump quits in October.
    As posted in #3, this is almost a carbon copy of the Northstar cars with the access hatch in the trunk ....... watch the video
    http://www.rockauto.com/catalog/more...333&cc=1379932
    TheFlash is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0 Turbo, 03 ThunderBird., 02 DeVille (gone)
    Nov 2012
    Las Vegas, NV
    71
    159
    the fuel pump assy. with fuel gauge replacement is not that easy. The plastic cup that holds the assy. is bigger than the hole in the tank. I replaced the level -sensor with out taking out the assy. I think the plastic gets hard and will not flex enough to fit through hole in the tanks.
  10. Remove Advertisements
