Bad Loss of power - 2003 Deville
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Bad Loss of power - 2003 Deville in Past Cadillac Vehicle Discussion; Over the last week especially, I'm experiencing very slow acceleration to the point where as thou , I'm having a ...
    cadillac griff is offline Cadillac Owners Fanatic
    Automobile(s): Deville 03
    Aug 2013
    Baltimore
    177
    Over the last week especially, I'm experiencing very slow acceleration to the point where as thou , I'm having a hard time goin from 2-4 gear! Even with my foot all the way down on the pedal ! Checked codes n got PCM 0410 n a rfa code which I discovered was for tire sensor ! Will a misfired spark plug show up on the dash! ? Thx
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    Re: Bad Loss of power
    Yes, a misfire will be detected by the PCM and will set P0300. A misfire would be obvious to feel though.
    If you are not able to speed up above certain point, you might be dealing with a clogged CAT. Clogged one doesn't always set codes. It's a very wild guess though.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,577
    Disconnect the exhaust system at the 4-bolt flange at the flex section. Wire it out of the way and go for a (loud) drive. Better performance ??? Clogged cat (from snake oil and slow driving). Replace it with either a Walker weld-on or an Eastern Catalytic direct fit model.
    The P 0410 says there's something going on with the A.I.R. system (emissions problem). Here in Maryland that's an emissions fail.
  5. #4
    68
    81,760
    I'm putt'in my money on the CAT.
  6. #5
    Aug 2013
    Baltimore
    177
    While just on my way home, my car couldn't pick up speed whatsoever , I really mashed it this time n the speed started decreasing! While on the side of the road an officer pulled over n offered to follow so I did that(surprisingly) lol... But when I started to make my way home , the car started goin ape chit! Lots of hesitation n jerking , took forever to get to 50mph... Despite all that I finally made it n went to mr tire where they said 117 for the diagnostic... Oh hold on that's s Northstar, oh no we don't mess with them, smh! But my car is parked now at my house n I checked the codes again n still PCM p0410 is all I got! Plz help !!!!! Oh yea, n did I mention as I was headed home that infamous glass shattering pop coming from the regulator but that's light right now, I'm more concerned bout not being able to drive!
  7. #6
    Feb 2006
    55,577
    Do as advised in posts 2,3,4 - disconnect the cat at the flex pipe and see if that "fixes" the problem. If so, clogged cat.
    EDIT: Please define "glass shattering pop from the regulator".
  8. #7
    Aug 2013
    Baltimore
    177
    Will do thx
  9. #8
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,997
    Quote Originally Posted by Submariner409 View Post
    That has to be the infamous pop 'n drop windows.
  10. Remove Advertisements
