rear door windows not working
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, rear door windows not working in Past Cadillac Vehicle Discussion; Hey guys its me agian good news i got a new 92 deville. the only problem is the rear windows ...
    Cadillac_Edd's Avatar
    Cadillac_Edd is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Cadillac Sedan DeVille, 2005 Escalade Ext
    Apr 2014
    Houston, Tx
    25
    175
    Hey guys its me agian good news i got a new 92 deville. the only problem is the rear windows not letting down and hazard lights not flashing. what could be the problem?
    xKingj's Avatar
    xKingj is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Deville
    Aug 2014
    Houston, T.X
    26
    Re: rear door windows not working
    Did you try checking the fuses
    Apr 2014
    Houston, Tx
    25
    175
    yes that the first thing i checked the hazards are tied in with the brake lights and they are working perfect
    Quote Originally Posted by xKingj View Post
    Plutonium239 is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Deville Base, 2004 Cadillac Deville
    Apr 2014
    22
    22
    I'm not certain if the 92 has relays for the power windows, but check to see if it does and if those work.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    If both rear doors do not work but the front doors do, I would suspect the master switch in the driver's door.
    If not that, then start checking the wiring in each door (after verifying fuses, etc)
    Hazard lights is probably the flasher module, located under the dash next to the steering column.
    Apr 2014
    Houston, Tx
    25
    175
    Quote Originally Posted by bigm57ict View Post
    ok how do the flasher module look I searched the internet to see how it look but no luck.
  9. Remove Advertisements
