Knuckle bushing 95 Deville 4.9L
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Knuckle bushing 95 Deville 4.9L in Past Cadillac Vehicle Discussion; which way do you push out the bushing? to the front of the car or to the rear?...
    rayjuswa is offline Cadillac Owners Fanatic
    Automobile(s): 1995 Deville
    Jan 2014
    Johnstown, PA
    68
    139
    Jan 2014
    Johnstown, PA
    68
    139
    Re: Knuckle bushing 95 Deville 4.9L
    I guess no one knows the answer to this question
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Montreal, Canada
    445
    Quote Originally Posted by rayjuswa View Post
    try here:
    http://www.cadillacforums.com/forums...e-bushing.html
    It should be obvious if you can see the outer steel lip of the bushing.
    Jan 2014
    Johnstown, PA
    68
    139
    First of all
    Thanks for responding
    Secondly, If I could see the outer steel lip of the bushing
    I wouldn't be asking the question
    The hyperlink you sent me is appreciated but of no help
    I'll go back to it again in case I missed something
    Sep 2011
    Montreal, Canada
    445
    First of all
    Thanks
    You are welcome.
    Jan 2014
    Johnstown, PA
    68
    139
    For anyone who wants to know
    The top rear knuckle bushing pushes out toward the front of the vehicle (95 deville) both sides
    The bottom rear knuckle bushing pushes out toward the rear of the vehicle, both sides
    I was lucky enough to find a top rear bushing that would not push out either way
    Actually damaged the removal tool trying to force it
    After a couple of hours, I finally firgured out the problem
    My brand new bushing removal tool would not fit onto the knuckle bushing casting opening
    Why, because the knuckle bushing casting had a flaw in it when manufactured
    The opening had a steel burr at the bottom that would not allow the pushing tool to enter the hole
    The tool is really nothing more that a socket, so I took used a slightly smaller socket from my tool box and the bushing popped out without a problem
    Unbelieveable, a simple job turned into an all day marathon because of a faulty part
  9. Remove Advertisements
