interchange instrument panel
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, interchange instrument panel in Past Cadillac Vehicle Discussion; Hello there. Is it possible to interchange the instrument panel from sts dts o dhs 2000 and up into a ...
    Edy-CBP is offline Cadillac Owners Member
    Automobile(s): None
    Nov 2013
    None
    7
    Hello there. Is it possible to interchange the instrument panel from sts dts o dhs 2000 and up into a deville base 2001.
    any advice?
    Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    From an STS, no.
    I assume you want analog gauges?
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    Re: interchange instrument panel
    What's the difference of the 98-02 STS cluster versus the 00-02 dhs, dts cluster?
    68
    82,082
    I believe you can swap a DTS or DHS DIC into a base Deville. I seem to recall Logan doing it in his "Fake DTS" conversion and saying it was plug n play.
    I think Edy is looking to convert a digidash to analog.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,489
    Quote Originally Posted by Edy-CBP View Post
    any advice?
    Thanks
    YES -
    the cluster from a 2000+ Seville STS - SLS -
    or Deville DHS - and DTS - will all work -
    and are "plug-n-play -
    HOWEVER -
    mileage is stored in the cluster -
    and ONLY a certified speedo shop can change it - $200 -
    a dealer/TECH2 can NOT change mileage -
    the solution is to buy a cluster with similar mileage -
    most sellers on ebay include the current mileage -
    another problem is the options that came on the donor -
    compared to the options on your car -
    if the donor car had TPMS - Tire Pressure Monitor System -
    and your car does not -
    every time you turn the ignition ON -
    you will get the DIC warning SERVICE TIRE MONITOR -
    because the cluster "knows" the option is there -
    but it has not "checked-in" -
    scrolling through the "INFO" button
    would also include the tire pressure for each tire -
    other options affect the code scanning process -
    if the donor car had "active suspension" -
    you will get codes for active suspension parts not "checking-in" -
    this is easy to "fix" - with a trip to the dealer -
    a TECH2 tool CAN change all the options stored in the cluster -
    the trick is to FIND a dealer willing to try it -
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    I guess I got lucky with the DTS cluster I acquired.
    I have two currently. One with 50K too many miles, and the one in the car I had to wait till I had 155k to install it.
    No warning messages, zip zilch nada.
    The worst part to the swap was disassembling the dash......
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,274
    Something to think about ............. from birth we are "trained" to recognize spatial/graphic differences instantly - it's an offshoot of instinct. A digital anything - watch, instrument panel, GPS - requires the thought process of see, recognition, numerals, brain process, "too hot". An analog display is instantly recognizable as good or bad, time, location.
    The button pushers and techies like things glitzy and numeric. Analog displays generally do not have to be "looked at" to make a go-no go decision.
    Automobile(s): None
    Nov 2013
    None
    7
    Thanks to all of you for your entries....
    and yes l am thinking in an analog cluster, the base car has TPMS but what you mean with "active suspenssion" and I have located a cluster around 75k miliage that is similar to actual.....
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,489
    the DTS model deville has F45 / FE3 electronic - or active - suspension system -
    the struts and shocks are constantly changing from soft to stiff - electronically -
    the BASE and DHS model Deville does NOT have this -
    Automobile(s): None
    Nov 2013
    None
    7
    Thank you very much
  13. Remove Advertisements
