how do i drain all of the coolant out
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Ranger
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, how do i drain all of the coolant out in Past Cadillac Vehicle Discussion; Hi I am new here I'm trying to do a blue devil treatment and I can't get all the coolant ...
    Billybeme is offline Cadillac Owners Member
    Automobile(s): 1998 devill
    Aug 2014
    55
    1
    Hi I am new here
    and I can't get all the coolant out, the petcock is open there's still coolant in the res.
    any idea's
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    If the coolant isn't draining from the surge tank, something's clogged. I assume other stop leak products have been dumped in?
    Not only will Blue Devil not work (the gaskets aren't the issue, it's pulled head bolt hole threads, the breach is ever moving and widening), but it will create more clogs, and make repair nearly impossible.
    How did you diagnose the HG problem?
    68
    81,922
    Re: how do i drain all of the coolant out
    By the way, you CAN'T get all the coolant out unless you hold the car upside down and shake it.
    Return the snake oil and put the money towards a proper repair or another car. Anything else is a waste of time, effort and money.
    RVMAN likes this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    ................ and perform immoral acts upon the heater circuit hoses using a wetordry shop vac.
    There are no block side drain petcocks, so a couple of quarts remains in the block, thus the "upside down" advice.
    photobob is offline Cadillac Owners Member
    Automobile(s): 2012 CTS AWD, 2005 DeVille
    Dec 2014
    58
    42
    Where is the drain petcocck?
    Feb 2006
    55,904
    On your 2001 Deville ??? Up inside the front crossmember lower area at the bottom of the driver's side radiator end tank.
    Dec 2014
    58
    42
    Thanks submariner, I found a thread about how to get at it. It looks like I have to remove the upper hose. Take out the pass side fan loosen the drivers side fan and slide it over to access. Does that sound right?
    68
    81,922
    Just remove the lower splash shield (#16).
    The drain is #13 (drivers side)
    Dec 2014
    58
    42
    Thanks again, ran out of time, have to do it next week.
  12. Remove Advertisements
