P1860 code
Results 1 to 13 of 13
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, P1860 code in Past Cadillac Vehicle Discussion; 2000 deville with P1860 code. I understand that its a code for a TCC solenoid and I have read all ...
    thetrance is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Oct 2010
    3
    P1860 code
    2000 deville with P1860 code. I understand that its a code for a TCC solenoid and I have read all about it. Could this be set by a bad brake/cruise control switch? no other codes
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,910
    Re: P1860 code
    It's the TCC actuator solenoid - a dedicated, monitored circuit.
    68
    81,926
    Re: P1860 code
    Quote Originally Posted by thetrance View Post
    No..
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    Re: P1860 code
    2000 deville with p1860 code. I understand that its a code for a tcc solenoid and i have read all about it. Could this be set by a bad brake/cruise control switch? No other codes
    no
    Oct 2010
    3
    Re: P1860 code
    Hmm okay...why is it that when I move the brake or cruise control switch I get a P0741 on top of the 1860? what is triggering that?
    Feb 2006
    55,910
    Re: P1860 code
    The TCC monitoring system, fed by a slew of circuits and fault conditions, is telling you that the TCC is stuck OFF....... because the control solenoid is dead.
    I never - never - use cruise so I never saw the P 0741 when I had the P 1860.
    Oct 2010
    3
    Re: P1860 code
    oh i see thanks!
    68
    81,926
    Re: P1860 code
    Cruise is irrelevant. I get P0741 with or without the cruise. If you have P1860, it will also set P0741. That's why you got it.
    Feb 2006
    55,910
    Re: P1860 code
    Never saw a P 0741. Not once........... either in the car DIC scanner or the ScanGauge-II.
    Scan, codes, P 1860, clear codes, SES off, back to gauges.
    68
    81,926
    Re: P1860 code
    That's odd. P1860 usually sets P0741.
    70cougar is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    725
    Re: P1860 code
    My 02 FSM says the test for P0741 will not run if P1860 is already set. But my experience was similar to yours Ranger - the 2 codes came together.
    68
    81,926
    Re: P1860 code
    That would explain why Sub never saw P0741, but the TCC was inoperative with the P1860. It just wasn't advertizing it.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    :yeah;
  16. Remove Advertisements
