I don't remember if the accessory position on the steering column worked before I had the stereo changed but I tried using the accessory position and it does not work. Radio doesn't turn on nor do the window work. They only work with the ignition on the run position.
Before I have the radio pulled, does anyone know definitively which fuse is for the accessory?
I thought I'd ask before starting to pull them all of one at a time.
Thank you for your help.
