2003 Deville - CMP codes and how many are there ?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2003 Deville - CMP codes and how many are there ? in Past Cadillac Vehicle Discussion; I'm getting codes for camshaft position sensor. I was told there were 2 of them. Are they the exact same ...
    chefdbyrd's Avatar
    chefdbyrd is offline Cadillac Owners Member
    Automobile(s): 2003 cadillac deville
    Feb 2014
    Phoenix, AZ
    5
    I'm getting codes for camshaft position sensor. I was told there were 2 of them. Are they the exact same part for both sensors? Thanks.
    basscatt's Avatar
    basscatt is offline Cadillac Owners Master
    Automobile(s): 89 Coupe DeVille, 95 Sedan DeVille, 03 SLS, two 02 DHS's
    Feb 2004
    Minnesota
    63
    9,694
    Re: 2003 Cadillac Deville
    Quote Originally Posted by chefdbyrd View Post
    only one camshaft position sensor -
    ACDELCO 2131580 - $51.06 - with free shipping -
    http://www.amazon.com/ACDelco-213-15...ype=automotive
    two crankshaft sensors -
    and BOTH should be replaced at the same time -
    ACDelco 213-1578 - $40.56 -
    ACDelco 213-1579 - $42.15 -
    both on Amazon.com -
    Submariner409's Avatar
    Automobile(s): 2002.5 F55 STS/65500mi, 2004 Ford F150 SuperCab4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    74
    44,150
    Re: 2003 Deville - CMP codes and how many are there ?
    Your thread title - I made it a bit more descriptive because there are a LOT of "2003 Deville" posts in Cadillac Forums.
    Google something like "cadillac forums 2003 northstar cmp" and/or "cadillac forums 2003 northstar ckp" for links to varioius discussions over the years.
    The CMP is the cylinder TDC reference signal sensor and is located on the face of the right (rear) cylinder head in front of the exhaust cam sprocket.
    There are two CKPs, on the left (front) lower side of the engine block. They are the ignition and injector triggers, receiving their signals from the reluctor wheel on the crankshaft.
    One CMP part number, two different CKP numbers.
    Pictures and diagrams in my albums - click my username, open the profile, left column, 2 albums 6 pages of Northstar stuff.
  5. #4
    66
    72,910
    #269
  6. #5
    chefdbyrd's Avatar
    Feb 2014
    Phoenix, AZ
    5
    Thanks for the information. Do u happen to have the 2 part numbers and where I can find these parts? I've called part stores and the info doesn't make sense. Your info was much more compelling. Thank you
    Sorry that last post was for submariner409. Thanks
  7. #6
    basscatt's Avatar
    Feb 2004
    Minnesota
    63
    9,694
    [QUOTE=chefdbyrd;12787930]Thanks for the information. Do u happen to have the 2 part numbers and where I can find these parts? I've called part stores and the info doesn't make sense. Your info was much more compelling. Thank you
    really?
  8. #7
    Feb 2006
    74
    44,150
    www.rockauto.com
    Make, year, model, Ignition.
    AC Delco parts.................. like in my albums.
    CKPs .....................
  9. #8
    66
    72,910
    Got mine from Amazon with free shipping.
  10. #9
    chefdbyrd's Avatar
    Feb 2014
    Phoenix, AZ
    5
    Thanks everyone for your help, helped a ton. I really appreciate it.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
