Had the a/c compressor replaced - a/c only working properly with high RPM
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By amunderdog
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Had the a/c compressor replaced - a/c only working properly with high RPM in Past Cadillac Vehicle Discussion; I guess this never ends with my caddy... when my a/c compressor clutch went up in smoke and flames I've ...
    DReffects's Avatar
    DReffects is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
    May 2013
    Germany
    338
    I guess this never ends with my caddy... when my a/c compressor clutch went up in smoke and flames I've replaced the compressor and removed the orifice tube.
    I then took the car to a special a/c shop to get the following things done:
    - full flush of the system
    - attachemt of the a/c lines to the compressor iteself
    - installation of a new dryer and orifice tube
    - refill of the system with R134a
    Payed 475$ for that (only labour, I provided the parts). The a/c now sort of works, but only gets ice cold when i crank up the rpm. shop tells me that's to be expected with such an old car. makes no sense to me, every active component of the ac is new. The shop filled the system with 0.9 kilogram of refrigerant. the FSM specifies 1.1 kilogram of R12. The shop told me that you need only 85% of the amount of the original R12 specs.
    Does this sound right for you? What would cause the a/c to run like it does or is this in fact the regular behaviour?!
    Thanks!
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: Had the a/c compressor replaced - a/c only working properly with high RPM
    Find a different A/C shop.
    Do not tell them anything except you are unhappy.
    See what they have to say about it.
    DReffects's Avatar
    May 2013
    Germany
    338
    Quote Originally Posted by amunderdog View Post
    Easier said than done. There's no one else in a 100 mile radius that would even touch an american ac here
    Since you own a '94 deville - do you have full a/c performance in idle?
    Feb 2010
    Sunbright, TN
    1,530
    I believe our A/C works just fine.
    The Deville just had a new compressor and associated parts replaced last year.
    Guess you need to get a quality set of gauges and figure it out then?
    Manual 2 Chassis and body Section 1B-1 maybe http://www.alldatadiy.com/
    There are some really good A/C threads on this forum.
    Me?
    I would travel the hundred miles
    DReffects's Avatar
    May 2013
    Germany
    338
    I did another test drive today. I guess I was fooled by the warm weather. According to a multimeter with a built in thermometer the A/C produces ~ 46-52° F during idle, while driving it gets down to 34° F. It still does not feel als cold as in my Chrysler but I guess I was proven wrong ;-) In fact, good thing i was wrong!
    Thanks for the help guys!
    Feb 2010
    Sunbright, TN
    1,530
    Good to read you have a happy ending
    Now you have time to search out those A/C threads on this forum (there were some really good ones) and confirm your conclusion.
    DReffects likes this.
    68
    82,058
    Was the condenser replaced? They are almost impossible to flush.
    They're blowing smoke up your ass to get you off their back. If everything was replaced, it should perform like new.
    Yes.
  10. Remove Advertisements
