2005 Deville stutters at all speeds: no codes coming up
Results 1 to 13 of 13
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2005 Deville stutters at all speeds: no codes coming up in Past Cadillac Vehicle Discussion; At first I thought maybe the throttle body was just dirty but I don't think the engine would stutter at ...
    Vagaso is offline Cadillac Owners Member
    Automobile(s): 2005 Deville
    Jun 2014
    25
    7
    At first I thought maybe the throttle body was just dirty but I don't think the engine would stutter at idle if it was that. So maybe its a dirty injector?? I have no clue. Anyone have more ideas?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,374
    Re: 2005 Deville stutters at all speeds: no codes coming up
    Quote Originally Posted by Vagaso View Post
    just to be clear -
    are you saying that you actually pulled the codes -
    and there are no codes stored?
    or are you saying there are no messages displayed on the DIC -
    have you inspected the TB?
    Jun 2014
    25
    7
    I'l saying that there's no current codes showing that could show what makes it stutter. My only current code that comes up is a b0429 but that wouldn't make the car stutter.
    68
    81,929
    Might be plugs or a coil. How many miles on it?
    Jun 2014
    25
    7
    83,000 miles
    68
    81,929
    At THAT mileage, plugs & coils should not be a problem, but stranger things have happened. You could take it to AutoZone and have them run your codes to see if there is a specific cylinder that is misfiring, but with no P0300 code I doubt you'll find one.
    When was the TB last cleaned?
    Lewis98272 is offline Cadillac Owners Fanatic
    Automobile(s): '02 Eldorado ETC 85k miles / Past: '03 Deville; '02 STS
    Aug 2013
    Texas
    176
    I have an '02 Eldorado ETC with 85k that would stutter almost all the time, ended up being the plenum gasket. A couple of months later my '03 Deville with 135k started doing the same thing. Ended up being the plenum gasket. The '02 STS hasn't had an issue with it yet though. With a stuttering car though you surely should be getting some PCM codes. What are your history codes? Those can tell a big story too, something clearly malfunctioned in order to set those codes, so don't rule them out either.
    68
    81,929
    Yeah, a plenum duct tear will almost ALWAYS set a P0171 & P0174 code.
    Jun 2014
    25
    7
    I did take it to autozone to scan it but there were no codes coming up. I don't know when the TB was last cleaned. I haven't even had it for a year yet.
    ronswanson's Avatar
    ronswanson is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Aug 2011
    Tennessee
    94
    Is there a difference between what the auto scan tool pulls and what the dash displays when you pull the codes yourself? I always thought they did the same thing?
    68
    81,929
    Clean the TB. It's free, easy and most likely is way overdue anyway and just might solve your problem.
    Quote Originally Posted by ronswanson View Post
    The only difference is the onboard diagnostics will only give a generic misfire detected code of P0300 while a scanner will narrow it down to the specific cylinder IE: P0304 or P0307 etc, etc.
    Jun 2014
    25
    7
    When I went to autozone they found no codes throughout the system but when I did the onboard I found the codes for the blend door.
    68
    81,929
    I think AZ's scanner only checks P codes.
  16. Remove Advertisements
