1999 Deville Help with Drivers side window
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1999 Deville Help with Drivers side window in Past Cadillac Vehicle Discussion; I have a 1999 Cadillac Deville, every now and then I hit a wrong button and the window will go ...
    crouch200 is offline Cadillac Owners Member
    Jul 2014
    I have a 1999 Cadillac Deville, every now and then I hit a wrong button and the window will go down but not back up. my ex would fix it by hitting some buttons and the window would go back up and say it was locked, its done this several times and the ex was always able to fix by tapping some buttons. SO getting out of my car i hit a bunch of the buttons by mistake and now the window will not go up. Does anyone one know what the reset is for it
    the only buttons are 1 for each window a button labeled 1 and labled 2 and a button for set and a button for exit. and one labled lock out.
    Thanks for your help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    There is no"reset", and no lock for the drivers window at all. Even when locked, all windows will operate from the drivers master controls.
    Sounds like you have a bad switch.
    Jul 2014
    Re: 1999 Cadillac Deville Help with Drivers side window
    Hmmm ok, I thought it did, cause he would hit one of the numbers button hold it down then exit there would be a couple of beeps and the window would start working again
    Sep 2010
    East Boston MA.
    29
    26,323
    The 1/2/set/exit buttons are for driver memory, nothing to do with window operation.
  7. Remove Advertisements
