Shift problem
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Shift problem in Past Cadillac Vehicle Discussion; Hi everyone, i got a Cadillac deville DTS 2000 and i got a new problem since a couple of week, ...
    Olivia26 is offline Cadillac Owners Member
    Jun 2014
    7
    Hi everyone, i got a Cadillac deville DTS 2000 and i got a new problem since a couple of week, when i'm on park it doesnt want to shift to D or even Reverse it stay block for a couple of minute sometimes 10-15 before it get unlocked its really weird because i have no problem while driving or anything its knly when i'm on park that she block and its stressing me anyone have any idea?
    Hi! I got a Cadillac deville DTS 2000 and i started having problem shifting from park to drive or wathever. Its doesnt moove from park its totally blocked here i dont know why. When im driving the car is perfectly well and dont cause me any problem and the liquid transmission is ok too...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,258
    Re: Shift problem
    Did you step on the brake when attempting to shift to/from Park ?
    Your post in the Lounge has an answer.
    EDIT: Duplicate threads merged. Please let one thread on one question work for you. DO NOT post multiple threads on the same train of diagnosis. Thanks for the consideration.
    Jun 2014
    7
    Yeah of course but nothing work shes stay block even if u put the break or even the bigger break i dont know why...but its not all the time tho. And my transnission liquid is fine dont miss any.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,999
    Re: Shift problem
    Do you hear a click when you step on the brake in park? If not, then your brake interlock solenoid is sticking.
    Jun 2014
    7
    No i dont hear any click...is that really bad? What do i have to change or get fix?
    68
    82,076
    Re: Shift problem
    The stop lamp/brake interlock switch (#11) at the top of the brake pedal activates the brake interlock solenoid. It tends to fail before the solenoid does.
    #10 is the CC & TCC disengage switch
    Jun 2014
    7
    So that means i have to make the switch check and change if need to? Is that a easy job not suppose to cost alot isnt it? If i understand the picture its rightbunder my wheel ?
    68
    82,076
    Re: Shift problem
    Quote Originally Posted by Olivia26 View Post
    Yes
    Easy and inexpensive
    Correct
    Jun 2014
    7
    Super thank you very much ill go direct on monday make it change :-)
    r_2016's Avatar
    r_2016 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Lexus LS430, 1993 Deville
    Sep 2005
    Boston, MA
    181
    Re: Shift problem
    I had one of these fail on my 93 Deville. It was an easy fix. Good luck
  13. Remove Advertisements
