Cylinder 1 misfire - 2002 DTS
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Cylinder 1 misfire - 2002 DTS in Past Cadillac Vehicle Discussion; what is the firing order for the 02 DTS? trying to find cylinder 1...
    caddy fever is offline Cadillac Owners Member
    Automobile(s): 02 Silver DTS , 00 Pear Eldorado ETC
    Apr 2014
    None
    22
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,547
    Re: Cylinder 1 misfire
    Bank 1 is the right (rear) bank: 1-3-5-7
    Bank 2 is the left (front) bank: 2-4-6-8
    There are several hoops to jump through in order to remove the right bank coil cassette. Cadillac Tech Tips and pictures/diagrams in my 2 albums
    Apr 2014
    None
    22
    Re: Cylinder 1 misfire - 2002 DTS
    thanks a million
  5. #4
    Apr 2014
    None
    22
    Changed all plugs coil packs and boots and I'm still getting the misfire
  6. #5
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,258
    Quote Originally Posted by caddy fever View Post
    check the fuel injector -
    with the engine running - use a stethoscope - or similar -
    and listen to the injector -
    there should be a clean - distinct "CLICK" each time the cylinder fires -
    what plugs?
    I hope you used OEM ACDelco or Denso -
    what ignition cassettes? new - used?
    still a #1 misfire?
    if yes - swap the coils -
    if the misfire goes to #8 -
    the coil is defective -
    if it stays at #1 - double check the plug and boot -
    if PERFECTLY clean - and no carbon arching on the boot -
    do a compression test on the rear cylinders -
  7. #6
    Apr 2014
    None
    22
    Will do a compression test .... I did use AC Delco plugs and new boots and swapped packs no aftermarket anything. I honestly believe that my catalytic converter is bad ... The car runs much smoothly but it puts...
  8. Remove Advertisements
