Door wont unlock with key fob
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Door wont unlock with key fob in Past Cadillac Vehicle Discussion; Any suggestions on wats wrong, trunk, alarm n door lock work, just won't unlock door!! And yes I changed the ...
    cadillac griff is offline Cadillac Owners Fanatic
    Automobile(s): Deville 03
    Aug 2013
    Baltimore
    177
    Any suggestions on wats wrong, trunk, alarm n door lock work, just won't unlock door!! And yes I changed the battery ,same result!
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Pop the fob apart again, and check for dirt between the rubber button pad and circuit board.
    Aug 2013
    Baltimore
    177
    I'll try now thx
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    Re: Door wont unlock with key fob
    Do you have another fob and does it work?
    The battery holders come loose and another part is know to work loose and needing soldering. Think maybe N*caddy had a post about them... I have soldered all mine I think at one time or another.
    Aug 2013
    Baltimore
    177
    Nope Carmax gave me one fob! I'll have to check for that soldering posts because cleaning it didn't work !!!
    delerium75's Avatar
    delerium75 is offline Cadillac Owners Fanatic
    Automobile(s): 1991 STS, 1992 Fleetwood, 1987 Maxima wagon
    May 2008
    Bay City, MI
    42
    276
    The underside of the remote buttons have some kind of coating that works with the electrical contacts to make the button work. If your other buttons work, take a look at the underside of the button pad and note if that button is worn (looks different in any way compared to the other buttons...like maybe a very black center compared to the others). Might be able to get away with a replacement button pad...eBay has them for newer remotes with just the pad or a replacement shell (minus electrical bits).
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    "Door wont unlock with key fob"
    A door or all doors?
    Aug 2013
    Baltimore
    177
    Quote Originally Posted by amunderdog
    "Door wont unlock with key fob" A door or all doors?
    DoorS , my bad.... Lock , trunk , alarm are all fine, door unlock button does nothing tho
    Quote Originally Posted by delerium75
    I was lookin on ebay while posting this and I saw a couple replacements , thx I think that's where I might have to look because that lil black button on the rubber pad appears to not be as full/depth as the other three!
    Feb 2010
    Sunbright, TN
    1,530
    There is supposed to be a way to test a remote fob.
    I thought this was interesting
    Aug 2013
    Baltimore
    177
    I just got my new fob(rubber pad n shell) and still same result.... Everything works but door unlock button! I followed a link as well which mentioned sandpaper n alcohol to the board, still nothing! Any other suggestions!???
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,481
    Quote Originally Posted by cadillac griff View Post
    inspect the printed circuit board - with a magnifying glass -
    specifically the soldered joint for the UNLOCK button -
    these are "cold-soldered" joints -
    and if/when the solder joint cracks - that button will simply not work -
    Aug 2013
    Baltimore
    177
    Ok I'll try that
  15. Remove Advertisements
