2000 DTS - Intermittent no start with codes P 0335 and P 0385
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 DTS - Intermittent no start with codes P 0335 and P 0385 in Past Cadillac Vehicle Discussion; 2000 Deville DTS Has intermittent no start. It has happened 3 times. Cranks over but will not start, after waiting ...
    T & D Auto is offline Cadillac Owners Member
    Automobile(s): none
    May 2014
    1
    2000 Deville DTS Has intermittent no start. It has happened 3 times. Cranks over but will not start, after waiting anywhere from 1 to 4 hours it will restart and run just fine sometimes up to a month of trouble free operation between no starts. when it fails to start, the check engine lights comes, each time setting DTC PO335 and PO385, crank shaft sensors a and b. I've heard this a common problem, any one know the end result fix ?? Thanks for any help.
    MoistCabbage's Avatar
    MoistCabbage is online now Cadillac Owners 10000+ Posts
    Automobile(s): Crimson 2001 Seville STS, 1990 Seville (RIP)
    Sep 2010
    East Boston MA.
    26
    20,443
    The fix would be to replace both CKP sensors. Google "Cadillacforums Northstar CKP replacement", or check the tech tips section.
    Hoosier Daddy's Avatar
    Hoosier Daddy is offline Moderator
    Automobile(s): 2013 ATS Performance 2.0T M6
    Feb 2013
    Winchestertonfieldville, AZ
    65
    3,584
    Re: 2000 Cadillac Deville DTS. Intermittent no start with codes po335 and po385
    Welcome to the forums. I moved your thread to the DeVille area
  5. #4
    SGWORLDWIDE's Avatar
    SGWORLDWIDE is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Deville DTS (Sold)
    Dec 2012
    26
    734
    Quote Originally Posted by T & D Auto View Post
    Exactly what it says crank sensors
  6. #5
    basscatt's Avatar
    basscatt is online now Cadillac Owners Master
    Automobile(s): 89 Coupe DeVille, 95 Sedan DeVille, 03 SLS, two 02 DHS's
    Feb 2004
    Minnesota
    63
    9,364
    the parts you need are -
    ACDelco 213-1578 - $36.99 - with free shipping -
    http://www.amazon.com/ACDelco-213-15...=AXD2GA81MIQMV -
    and -
    ACDelco 213-1579 - $39.95 - with free shipping -
    http://www.amazon.com/ACDelco-213-15...A1GJX4SJF8V2R0
  7. #6
    66
    72,325
    Re: 2000 DTS - Intermittent no start with codes P 0335 and P 0385
    Been there, done that. GM had a bad supplier from 2000-2003. Replace both sensors and your problems will disappear.
    You'll need to remove the oil filter adapter to get access. Not much room down there. You'll need a long extension and a universal joint.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
