noise after rolling over small bumps
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Ranger
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, noise after rolling over small bumps in Past Cadillac Vehicle Discussion; Hi Guys, The car rides smooth; new inner and outer tie rods, lower control arm,new rear air shocks; and a ...
    Jorge Lugo is offline Cadillac Owners Member
    Automobile(s): Deville 2004
    Sep 2011
    Bronx, New York, United States
    56
    8
    Hi Guys,
    The car rides smooth; new inner and outer tie rods, lower control arm,new rear air shocks; and a good alignment. Just one concern when rolling over small bumps, a noise similar to a low horn is produce after the bump. I'm like curious George need to know what making that noise. Thank You.
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    Re: noise after rolling over small bumps
    A horn noise?? Is that a groan?
    What year and is the noise from the front or the rear? If rear, the rear knuckle bushings are known to squeak, push down on back and see if it squeaks.
    68
    82,055
    Please update your profile to show the year of your car so we don't have to ask in the future.
    Jorge Lugo likes this.
    Sep 2011
    56
    8
    I rowed down the windows the noise is likely to be from the driver side; it sounds like a pluck the same tone when you run over a loose manhole top. I believe is coming from the front. I hope is not the lower control arm. I have to lift the car to make an visual assessment.
    68
    82,055
    Also check the sway bar and link bushings.
    Sep 2011
    56
    8
    I will plan a day to review the work of the individuals that made repairs to my Caddy; Thanks for the heads up on the sway and links; they were recently replaced by a non-reliable shop they also deflated the rear tire. I'm disable person but have the courage of the men with the force of 10 army battalion.
    Sep 2011
    56
    8
    My father show me treat people with respect; apologize to the people who changed the sway bar links; those are fine. After a review of the suspension I noticed that all brake pads and rotors need to be replaced ; the rear and driver side brakes are in bad shape. Two years past since I haven't change these items. It's time to do research for parts and pricing.
    Sep 2011
    56
    8
    Issue resolve, the nearly three year rear rotors were warp, and pads had about 30% of life. All rear brakes replaced. Had an issue with one of the bleeding valve; Jesus Christ came to my rescue; and the work was completed. All the worked was done on the street in NYC just imagine how much stress a person needs to tolerate, keeping an extra eye on your tools. Kept the car in the same parking spot due to low volume of space. Spent my evening think if the bleeder valve will hold; today; rode my vehicle, driving was smooth, no noise after rolling over bumps and braking was quiet and smooth. I have to Thank Jesus Christ for helping me.
    68
    82,055
    Warped rotors are a myth. Rotors are made of cast iron. They do not warp.
    Goldencletus is offline Cadillac Owners Fanatic
    Automobile(s): 1998 DeVille Concours, 2004 Nissan 350Z Roadster
    Feb 2013
    Gold Country of California
    60
    109
    Something happens to them, warped or otherwise. I had a serious pedal pulsation (on my 98 Concours and my 96 Silverado) under braking until I had the rotors turned. I could see on the lathe where the tool was missing part of the rotor. after turning the rotors the pulsation was cured. If not "warped", what is the issue?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It's called runout, excessive runout causes the pulsation. The rotor wears unevenly side to side, it does not warp. Pulsation can also be caused by excessive pad material buildup in the rotors.
    68
    82,055
    Quote Originally Posted by Goldencletus View Post
    What would cause a warped rotor?
    It's an uneven build up of brake pad residue (not even visible). I've had it several times and I can usually cure it by riding the brake for about 1/2 mile or so (obviously a brake lathe works as well). In fact I'm about do for a clean up now.
    This will explain it better.
    http://www.stoptech.com/technical-su...nd-other-myths
    Another explanation (and debunking the "warped rotor" myth) is improper rotor installation.
    http://www.hendonpub.com/resources/a...etails?id=1787
  15. Remove Advertisements
