Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: 1996 Deville troubleshooting TC0023
    Robk46 is offline Cadillac Owners Member
    Automobile(s): NONE
    Feb 2011
    10
    1996 Deville troubleshooting TC0023 - FIXED!!
    Hello all,
    My friend recently bought a very nice 1996 Deville. He needed a car to get him to work, and didn't want the usual small economy car. He just returned from living in England for a couple years, and wanted a big car. I actually suggested a Buick with the 3800, but he just fell in love with the big Caddy, so here we are.
    TC0023 is showing up, which means the front right wheel sensor. I've ohmed out the sensor, and got 1100, which is within spec. I've check and cleaned the connections at the sensor, as well as the one coming out of the shock tower area. I've measured voltage coming out of the connector at 4.1 volts with ignition on. The computer TCS data mode shows all sensors reading the same as you're driving down the road: At 56 mph in cruise, I was getting RF-84 LF-84 RR-85 LR-85. I assume the slight number difference was because of the tire pressures.
    What else can I check? I thought for sure the RF wheel sensor would have a crazy reading compared to the other 3? Is there a decision tree somewhere I can look at?
    BTW - Running the codes on this thing is really cool. I wish all cars had this capability.
    Thanks!
    UPDATE - FIXED!! Drove it for 40 miles with my temporary tinfoil fix in place, and no codes so far.
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,701
    Re: 1996 Seville troubleshooting TC0023
    If that's the car you are talking about in Pic it is a DeVille...
    Automobile(s): NONE
    Feb 2011
    10
    1996 Deville code RS0028 troubleshooting
    Hi all.
    Has anyone gotten an RS0028 and fixed it? The code indicates a RR strut solenoid failure. I'll crawl under there after work and check the wiring. Anything else I should check, voltages, resistance, tail light bearings? http://www.cadillacforums.com/forums...lies/dizzy.gif
    Thanks!
  5. #4
    Automobile(s): NONE
    Feb 2011
    10
    Re: 1996 Deville troubleshooting TC0023
    Changed. Thanks
  6. #5
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The solenoid controls a variable orifice in the shock to adjust damping force. It's not serviceable, you'll have to replace the shocks. Active replacements are very expensive. You can replace them with passive shocks, and use resistors (actually your year/suspension system may need a relay) Ro disable the codes. Or if you want, just install the resistor/relay and leave the old shock installed.
    Is this a base or Concours?
  7. #6
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    More than likely the sensor in the hub is bad... Timken from either RockAuto, Amazon, Ebay etc...
    Did a quick Google on the code and some 96 Seville(yea go figure) had wiring issues going to that wheel. Something about interference, a new wire or insulating that wire helped. Try a search here also.
  8. #7
    Automobile(s): NONE
    Feb 2011
    10
    Re: 1996 Deville code RS0028 troubleshooting
    It's a base. Doesn't say Concours anywhere I can see.
  9. #8
    Sep 2010
    East Boston MA.
    29
    26,323
    Yeah that's a base.
    I think your car has the speed sensitive active suspension system that would require the relay, but someone else will chime in to confirm.
  10. #9
    rodnok01's Avatar
    Feb 2012
    NC
    6,701
    The 96 used on off elec suspension parts... I avoid that year just because of that.
  11. #10
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Quote Originally Posted by rodnok01 View Post
    rodnok, Is this the FWD series that had a problem with ignition interference (EMI) screwing up the suspension data bus ??
  12. #11
    Automobile(s): NONE
    Feb 2011
    10
    In doing a google search, I found someone who wrapped tin foil around the wiring harness behind the coils, and his code went away. I'll give that a shot in the name of Faraday and science.
    If the sensor in the hub was bad, wouldn't it have a different speed reading than the other 3?
  13. #12
    69
    82,278
    Quote Originally Posted by Robk46 View Post
    TC0023 means "RF Wheel Speed Sensor Continuity Fault". I'd replace the hub & bearing assembly.
    P.S.
    Please do not double and triple post for the same problem.
  14. #13
    Automobile(s): NONE
    Feb 2011
    10
    P.S.
    Sorry, I actually posted first in the Seville area by accident, but I posted the TC0023 and RS0028 in the Deville area as separate posts because they are separate systems and problems. Thanks
  15. #14
    Automobile(s): NONE
    Feb 2011
    10
    Fixed!!! I just folded up a thick section of tinfoil and wedged it behind the coils. Cleared the codes, and they haven't come back! I'll make a shield out of sheet metal and see if that works. I'll probably mount it under the coil pack somehow, with it separating the wiring harness from the coil pack and wires. Here's a pic of my temporary test fix.
  16. #15
    69
    82,278
    That might save your HVAC blower as well.
  • You may not post replies
