1994 deville concours coolant leak
Page 1 of 3 123 LastLast
Results 1 to 15 of 42
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1994 deville concours coolant leak in Past Cadillac Vehicle Discussion; okay i noticed coolant on the bottom of car but from the left side... inspected the hoses and stuff around ...
    jmanuel's Avatar
    jmanuel is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Deville Concours
    Jul 2013
    Northern Ca.
    24
    59
    okay i noticed coolant on the bottom of car but from the left side... inspected the hoses and stuff around that general area and nothing. started engine and revd a bit then noticed coolant splashing out of that overfill tube thing that points straight down? heard like a clicking noise from aroud the leftside belt then car shut off?? help
    69
    82,266
    Re: 1994 deville concours coolant leak
    Left side is the drivers side, but you seem to be talking about the right (passengers) side. Left & right are always give as viewed from the driver seat.
    Are you saying coolant is leaking from the recovery tank overflow tube?
    Clicking noise might be a bad bearing on the WP, tensioner or idler pulley.
    jmanuel's Avatar
    Jul 2013
    Northern Ca.
    24
    59
    okay and yes the overflow tube .. what could cause that?
    and no not from the water pump belt but from the other side
    the right side by the recovery tank. i just replaced wp
    galen717's Avatar
    galen717 is offline Cadillac Owners Member
    Automobile(s): '99 Concours, '93 Sedan Deville, '71 Fleetwood Brougham
    Jun 2013
    Atlanta, GA
    81
    Has it been overheating? Is that why u replaced wp?
    69
    82,266
    If it is overflowing from the overflow tube, there can be only one reason, the system is being over pressurized and there can only be one of two reasons. Either it is overheating or it is being pressurized by a bad HG.
    jmanuel's Avatar
    Jul 2013
    Northern Ca.
    24
    59
    no it was leaking alot so went in to change it.
    okay well how can i know which one of the two is causing this to haappen?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Is it overheating? If not, time for a block test.
    69
    82,266
    You could either do the block test or try replacing the cap. I think it may be 6 of one or a half dozen of the other as to which you do first.
    jmanuel's Avatar
    Jul 2013
    Northern Ca.
    24
    59
    icant tell if its overheating i dnt have a temp gauge. 94 deville conours.
    iknow it shutss off tho. yeah someone told me it could ve the cap or thermo ill try those.
    how would i go about doing a block test. and what would you try soing first to last?
    Sep 2010
    East Boston MA.
    29
    26,323
    It won't shut itself off if it overheats (or for any other reason). Are you getting an engine hot warning?
    Replace the cap, if it still does it, rent a block test kit from a parts store. It will come with instructions, and there are also videos on YouTube.
    jmanuel's Avatar
    Jul 2013
    Northern Ca.
    24
    59
    it shut itself of twice. as far as the temp light iwas outside car while it shut off and havent drove it sonce i found leak so iwouldnt know if it would come on. should i do a drive around the block? ill do that thanks so much im pretty much lost wothout this forum
    Sep 2010
    East Boston MA.
    29
    26,323
    Let me clarify. The car will not shut itself off to protect itself for any reason. If it shut off, it simply stalled for some reason, so that's a separate issue. Fill the system to the proper level and drive it, see of it overheats.
    jmanuel's Avatar
    Jul 2013
    Northern Ca.
    24
    59
    problems on top of problems great ha thanks tho. but okay ill drive it to get a new cap
  16. #14
    jmanuel's Avatar
    Jul 2013
    Northern Ca.
    24
    59
    but on new cap turned on car.. no more leaking. drove around to see if it would overheat all looked good parked to check if leaking no leak. revd car a lil then boom bunch of white smoke from under the hood. checked oil dipstick and its way overfilled and the overfill tank looked muddy like chocolate im guessing bhg? lol
  17. #15
    69
    82,266
    OUCH! A HG will not leak externally and cause under hood "smoke" (or steam). Whatever it is sounds like major problems.
  18. Remove Advertisements
