Is it a sticky thermostat? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Is it a sticky thermostat? in Past Cadillac Vehicle Discussion; I don't trust Stant. On other cars I've owned they farked up the design, causing the unit to expand against ...
  1. #16
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,374
    Re: Is it a sticky thermostat?
    I don't trust Stant. On other cars I've owned they farked up the design, causing the unit to expand against the housing and bend BADLY. I wish I could find the photos I took.
    For now, I think I'm going to keep an eye on the gauge and leave it alone until it gets worse or more obvious.
  2. #17
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,925
    Quote Originally Posted by Jesda View Post
    It was an error for failing to enter fuel system open loop or some nonsense. Issue was the thermostat. On road trips through cold climates, the needle would stay planted at one mark left of center, failing to reach full operating temperature,
    Yep ^^^ - Depending on ambient temps the emissions systems don't fully click in (go closed loop) until a coolant temp of between 140 and 160 degrees. That 160 corresponds to just about the tick mark at 11:15. (Post 3).
    Never had a problem with a Stant cooling system part in 60 years. You could try a Gates branded 'stat, and AC Delco will be either/or Stant or Gates depending on the current state of the supply contracts.
    Even though the 'stat is in the return hose the temperature cartridge (copper case with wax pellet) points TO the engine/water pump. These 'stats are acted upon by the block and heater circuit temperatures.
  3. #18
    68
    81,929
    How do you know it was the thermostat if you haven't changed it?
  5. #19
    Jesda's Avatar
    Sep 2003
    DETROIT
    35
    22,374
    I was referring to my former Seville.
  6. Remove Advertisements
