Navigation didn't turn on in my 02 DTS
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Navigation didn't turn on in my 02 DTS in Past Cadillac Vehicle Discussion; Hey ppl, I'm new to the forum !!! I have 00 Pearl Eldorado with 140,000 and a 02 Silver DTS ...
    caddy fever is offline Cadillac Owners Member
    Automobile(s): 02 Silver DTS , 00 Pear Eldorado ETC
    Apr 2014
    None
    22
    Hey ppl, I'm new to the forum !!! I have 00 Pearl Eldorado with 140,000 and a 02 Silver DTS with 103,000 . I went to start the 02 yesterday morning and I noticed that navigation didn't power up and everything else did . It has happen before maybe 2 weeks ago it did this and I disconnected the battery for a bit and it came back. Yesterday it didn't work, also the chime wasn't working either. What should I do ???? Please help
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Did you check both fuse boxes?
    Apr 2014
    None
    22
    Yes I checked both and not one fuse is blown , it came back on for a second. I thought it worked but when I went back out it was off again
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    Re: Navigation didn't turn on in my 02 DTS
    Please do not post multiple threads and questions on the same problem. Threads merged.
    Apr 2014
    None
    22
    Quote Originally Posted by Submariner409 View Post
    Sorry I'm new
    Sorry guys I'm new and haven't got this full yet, please try and bare with me
    69
    82,163
    Don't know much about the NAV system.
    Have you pulled the DTC's?
    Apr 2014
    None
    22
    Amp u1000
    ddm b3832
    ipm b0428
    pcm p0135
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,564
    Quote Originally Posted by caddy fever View Post
    Amp u1000
    ddm b3832
    ipm b0428
    pcm p0135
    codes are meaningless without their definitions -
    Apr 2014
    None
    22
    Quote Originally Posted by basscatt View Post
    All codes said that they were current. I really couldn't tell you anything else. Nothing has happened since i purchase the vehicle
    Feb 2006
    56,582
    Use the link to code definitions - OBD-II - in the sticky post. We haven't memorized the several thousand GM codes yet. YOU need to define them and post that here.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,564
    each Diagnostic Trouble Code is different -
    the DTC is "SET" when a specific device has a specific problem -
    B0428 - is the code -
    the DEFINITION is Air Mix Door #3 Inoperative Error
    this code means the #3 mix door (controls the rear seat temperature) isn't moving -
    go here for a list of CODE DEFINITIONS -
    http://www.cadillacfaq.com/faq/answers/dtccode.html
    always include the definitions along with any codes you may have -
    Apr 2014
    None
    22
    After looking up the codes and troubleshooting all of them the only thing I'm left with is amp u1000 which is a class 2 communication . I honestly don't know what that means
  15. Remove Advertisements
