Im at a standstill,4 dead coil-packs?? 99Deville
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Like Tree1Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Im at a standstill,4 dead coil-packs?? 99Deville in Past Cadillac Vehicle Discussion; Well guys!!.I have a 99 Cadillac deville,that was a daily driver untill last Friday when it stalled as I was ...
    northstar87 is offline Cadillac Owners Member
    Automobile(s): 99 deville
    Apr 2014
    30
    9
    Well guys!!.I have a 99 Cadillac deville,that was a daily driver untill last Friday when it stalled as I was pulling out onto 59!. 20+re-start attempts later,we towed it home! Checked fuel pressure, battery V an ignition coils...An what do u know, coil-pack is dead!? It's getting input voltage just no HV output? An I doubt all four packs took a dump on me..so what sensor/sensors would cause this? Thanks
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    Re: Im at a standstill,4 dead coil-packs?? 99Deville
    Have you pulled the codes?
    Simple answer sounds like ICM took a dump...
    Apr 2014
    30
    9
    Yep,an didn't tell me anything! My friend has a OBD 2 scan tool that I'll hook up tonight an see if that works!!..appreciate the info,rodnok01
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    Built in scanner shows way more than hand helds except for very high end(Tech II) and the like.
    Post any and all codes with definitions.
    68
    82,056
    There is no such thing as a "coil pack". Chances of all 4 coils failing at the same time are just about nil. I'm with Rod. I'd suspect the ICM (it's what the 4 coils are mounted on).
    Apr 2014
    30
    9
    Quick update, it's not the icm! Soo,I guess its time to replace cam sensor an both crank sensors!
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    i wouldn't do that either
    at this point i'm guessing one of the weird grounding issues that this generation seemed to have problems with
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    I don't believe failed of either would cause a no start, a limp mode maybe and they will throw codes if the crap out completely. Have you pulled the codes??
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    Are your sure it has no spark?
    You may want to check your injector fuse(s) first, if you didn't already.
    Apr 2014
    30
    9
    Yes I have,i will post them as soon as I get off.
    Apr 2014
    30
    9
    P1375-IC 24X Reference Circuit High Voltage.. Should I replace all three sensor? Cam/crankA/crankB..already replace the cam sensor .
    rodnok01's Avatar
    Feb 2012
    NC
    6,650
    http://www.cadillacforums.com/forums...ltage-too.html
    I would check the wiring going to the ICM also carefully, there have been a couple issues with pins pulling out IIRC or just bad connections.(pins collapsed on one fellow and had to be opened up to make a connection)
    68
    82,056
    This will show you what each of the 4 ICM connectors are for.
    rodnok01 likes this.
  16. #14
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    There should be a ground attached to steel base were the coils sit. Just a suggestion.
    Need parts for your Northstar Engine? www.northstarperformance.com
    Evrett, Sales Executive of the SureGrip™ Cylinder Head Stud Kit
  17. #15
    Apr 2014
    30
    9
    My nightmare is over!!!!
  18. Remove Advertisements
