2002 DHS P 0410 and high idle up to 3000 rpm
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2002 DHS P 0410 and high idle up to 3000 rpm in Past Cadillac Vehicle Discussion; I have a 2002 deville dhs 110000 miles just changed the air control valve and TPS (which was not easy ...
    Blotto is offline Cadillac Owners Member
    Mar 2006
    23
    I have a 2002 deville dhs 110000 miles just changed the air control valve and TPS (which was not easy due to brackets in the way) andway I get a P0410 code and when I clear it it stays off and then comes back on maybe a day later...and as I was stopped in a parking lot in park the car simply jumped up to 3000 rpm throwing no codes...I turned the car off and restarted it and it was back to around 680rpm...and it also seems not to decellrate well the rpm seems to stay steady even though I took foot off pedal...but when breaking it seems to calm down to around 680..i have a scanner tool and the only code it throws is the P0410 ..seems the vacumme lines are OK m at a loss..if you can help please do thank you steve
    68
    81,883
    Re: 2002 deville DHS P0410 and high idle up to 3000 rpm
    What does P0410 mean?
    When was the TB last cleaned?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I think it's an A.I.R. System code.
    Quote Originally Posted by Blotto
    A.I.R. Valve or IAC?
    Mar 2006
    23
    it was my bad I replaced the IAC not the air valve...and I cleaned the TB last weak...it was not real dirty but in need of cleaning...cleaned it while on the car...im thinking its the Intake boot...I tried spraying starter fluid but no result of higher rpm but ill try again...it also after about 12 hrs threw the po410 code...I may just have to pull the intake cover and just eat the time if its not the boot....ALSO...if there is only one air pump relay on the rt back fire wall does that mean there is only one Air Pump (smog pump) its possiable this is not working but I cant tell just yet the vacuum sound does not seem to be there at cold start up ..still only code is the P0410 code and no more..thank you steve....
    P0410 secondary air injection system AIR system
    When was the TB last cleaned? Cleaned last week....apr 3 2014 I think//.....
    IAC was replaced NOT the valves..
    68
    81,883
    A ripped plenum duct will set a P0171 & P0174 code. Flex it near the bottom while spraying to check it.
    P0410 refers to the AIR pump or the check valve.
    http://www.obd-codes.com/p0410
    Mar 2006
    23
    So far no codes except the P0410...the high random rpm in park bothers me it went from a normal 670 or so to 3000..just sitting in a parking lot...im more wprried about that I am clueless about it really maybe the tps got stuck?..though it shows working fine on the scanner pids...thanks for your input..
    68
    81,883
    Re: 2002 DHS P 0410 and high idle up to 3000 rpm
    That RPM jump almost has to be the IAC valve or the TPS. I can't imagine anything else that would cause that.
    Mar 2006
    23
    I have to agree with you..i will take a look at this again and reinstall the new parts..and just eat it and replace the air pump and then see what happens and check the plenum and air intake ..all again..and vacuume hoses.does anyone know if the vacuum hoses are 5/32 hoses of 7/32 hoses or does it matter.....according to the dealership sewell no parts dept has them stocked but thy can order them 25 bucks a piece for like 8 of them it think lol.....thanks for posting Blotto
    68
    81,883
    Just measure your hoses or take one with you. You can buy vacuum hose by the foot from any parts store (MUCH cheaper than that).
    Mar 2006
    23
    bought vacuum hose 5/32 from ebay 21 bucks 50ft roll........also bought a air pump at RA 131.00 with 5% discount...so ill install this see if I can get rid of the code..and see what happens..i sure hope its not the air check valves 150 each and there are two ..thank you blotto
    Sep 2010
    East Boston MA.
    29
    26,325
    Why on earth did you need a 50 FT roll of vacuum hose??
    68
    81,883
    That should last 2 or 3 lifetimes.
    Mar 2006
    23
    well I have other uses and it was like 5 bucks more then what I needed..(smile) besides the may be a shortage some day...lol blotto
    well I hope I live that long...lol blotto
  16. #14
    Mar 2006
    23
    OK replaced the smog pump air pump and inspected the vac hoses code has not reset yet after about 150 miles of normal driving I installed the new air pump hose as per gm's advice..this ar has only 1 air pump instead of 2..so all seems to be well....the next issue is the decellaration the car does not decelerate like it should take the foot off and it keeps a higher rpm then needed when you break it seems to slow down its weird..i replaced the tps and the iac another hunt....and it seems to me the ignition and firing is not as good as it should be both ignition moduals were replaced at difffrent times some time ago...I may pull all that and change the spark plugs the springs and see if that helps getting that rear air valve off is a problem..jezz who engineers cars anyway bucket of bolts....THANK YOU ALL FOR REPLYING IT HELPS ALOT...Blotto
  17. #15
    68
    81,883
    So you cleaned the TB, replaced the TPS and IAC valve, replaced bad vacuum lines and it still idles high? Have you checked for a ripped plenum duct? That should set a P0171 & P0174 code though.
  18. Remove Advertisements
