2000 DTS - ELC not raising vehicle
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 DTS - ELC not raising vehicle in Past Cadillac Vehicle Discussion; I have just replaced the rear shocks and springs with yhe monroes and installed the resistors. The compressor kicks on ...
    victor1208's Avatar
    victor1208 is offline Cadillac Owners Member
    Automobile(s): 2000 deville dts
    Apr 2014
    Longwood Fl
    38
    4
    I have just replaced the rear shocks and springs with yhe monroes and installed the resistors. The compressor kicks on at initial start up but will not level the vehicle or fill the shocks. Checked all sensors and relays and they are working. Only code is rss c0577 for front solenoid.. could this make the elc not work? also i just installed 22" rims. Any help would be great.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,569
    Re: 2000 DTS - ELC not raising vehicle
    Quote Originally Posted by victor1208 View Post
    there should be at least a small amount of air pressure in the bladders at all times -
    the easiest way to test the system
    is to disconnect the bottom of the the height sensor rod -
    if you push the rod UP - this simulates a low rear end -
    and should signal the compressor to turn on - and inflate the bladders -
    when the bladders are inflated - move the rod about half way DOWN -
    that will simulate LEVEL height - and the compressor shuts off -
    the car should remain at this height forever -
    UNLESS there is a leak -
    move the rod DOWN - will simulate the rear too high -
    and signal the exhaust valve to open - and release air pressure -
    until the rear is once again level -
    IF the rear sinks down when inflated - there is a leak -
    best way to check for leaks is a mixture of dishwashing soap and water -
    spray it on all the connections - watch for bubbles -
    if no visable leaks - it could be a faulty exhaust valve in the compressor -
    victor1208's Avatar
    Apr 2014
    Longwood Fl
    38
    4
    thanks for replying. i tried that amd the compressor didnt kick on. then i checked for power when it was moved up and down amd there was power.
    69
    82,177
    If you moved the sensor/switch up and down and there was power, but you got no response, the switch/sensor is bad.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    That should set a code.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,569
    you need to be more clear about the power -
    there was power WHERE?
    if there was power to the compressor -
    but the compressor did NOT start -
    the compressor is the problem -
    you can buy a brand new GM compressor for around $235 -
    used for around $100 -
    $25 at the MAN'S MALL -
    in the mean time -
    the rear shocks NEED a small amoun t of air pressure - 14PSI - minimum -
    if it's going to take any length of time to fix - or decide to fix -
    you should install the Monroe AK29 Manual Fill Kit - around $12 -
    victor1208's Avatar
    Apr 2014
    Longwood Fl
    38
    4
    sorry. the power was at the height level sensor. i read on here to check for power when moving the arm up and down. there was power when it moved..but the compressor did not kick on. i do havve the monroe air kit and i guess i will install it until i figure this out.
    victor1208's Avatar
    Apr 2014
    Longwood Fl
    38
    4
    i installed the monroe manual fill kit and everything is much better. I am going to wire the compfressor to a switch so i can levwl the car muself. does anyone know where i can find a wiring diagram for the elc system?
    69
    82,177
    FSM or a subscription to www.alldatadiy.com
  12. Remove Advertisements
