1993 Deville, Doors Unlock Themselves
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1993 Deville, Doors Unlock Themselves in Past Cadillac Vehicle Discussion; Hello Everyone, I am writing this post so I can get advice to solve an electrical problem that my 1993 ...
    mekrob is offline Cadillac Owners Member
    Automobile(s): 1993 Sedan Deville
    Jun 2013
    3
    Hello Everyone,
    I am writing this post so I can get advice to solve an electrical problem that my 1993 Deville is having.
    The power locks on all four doors will unlock themselves while I am driving and also when I leave the car sitting for any period of time.
    I attempted to fix the problem by disconnecting the keyless entry module (somewhere online suggested this might work). This did not work.
    Has anyone encountered this problem and/or know how to fix it?
    Thanks for considering my issue,
    Jay
    68
    81,926
    Re: 1993 Deville, Doors Unlock Themselves
    Start by pulling the DTC's. Post them AND their definitions.
    Jun 2013
    3
    First code: ..E
    I understand this to mean that the onboard diagnostic is telling me that it will be displaying error codes from the electronic control module.
    2nd code: E52
    Memory reset. This is b/c I unplugged the negative terminal when I removed the keyless entry module.
    Final code: .7.0
    This simply means the onboard diagnostic system is done displaying error codes
    DReffects's Avatar
    DReffects is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
    May 2013
    Germany
    338
    E52: is set every time you unhook your battery or pull some fuses. don't worry about that
    apart from that i can offer very little input, sorry
    still_walkin's Avatar
    still_walkin is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Cadillac deville sedan 1986 cadillac deville RIP
    Apr 2007
    san diego
    33
    1,498
    Mine did tht one time and the trunk and gas door poped turned out bad battery. The voltage gets to low and the caddys electronics go crazy. To be on the safe side check your alts voltage regulator
  8. Remove Advertisements
