Hydraulic Mount
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Hydraulic Mount in Past Cadillac Vehicle Discussion; Greetings, I'm trying to see what people are using for the hydraulic mount on their Deville's, since appartently GM discontinued ...
    Deville4Jesus is offline Cadillac Owners Member
    Automobile(s): 1989 Sedan Deville
    Aug 2013
    30
    Hydraulic Mount
    Greetings,
    I'm trying to see what people are using for the hydraulic mount on their Deville's, since appartently GM discontinued the mount.
    This is on an 89 Sedan Deville.
    I replaced this mount a year ago, with an Anchor mount, and it failed in about 4 months. Any thoughts? I had an order cancelled through GM Parts Direct today for this order, even though it was available on their website and the order went through (originally).
    This is the mount: http://www.amazon.com/Anchor-2554-Fr...1&s=automotive
    It's #1 in this diagram:
    Here's the email:
    Thank you for ordering from GM Parts Direct .
    We regret to inform you that the following item is currently unavailable:
    Part Number: 22188804
    Part Description: engine, engine / transaxle, engine & trans mounting, motor mount GAS ENGINE, hydro mount Right
    Reason: Discontinued
    Thanks for your help! I am stumped!
    Aug 2013
    30
    Re: Hydraulic Mount
    Anyone know when they discontinued these and what the best way-ahead is? Should I try a DEA mount?
    Aug 2013
    30
    Re: Hydraulic Mount
    Can anyone help to shed some light on this? Thanks!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,582
    Re: Hydraulic Mount
    Quote Originally Posted by Deville4Jesus View Post
    personally - I prefer the Anchor brand over OEM or DEA -
    the Anchor 2552 can be had for $14 with shipping -
    http://www.amazon.com/gp/product/B00...A1T0VEFK4F7RX4
    the OEM - GM 22188804 - can be had for $75 - with shipping -
    http://www.ebay.com/itm/GM-MOTOR-MOU...a36d45&vxp=mtr
    Aug 2013
    30
    Re: Hydraulic Mount
    Thanks bass! Since I've already "torn" an anchor mount fairly quickly, what would you suggest? Is it possible the one I bought was a poorly constructed and had a lower fail point for the rubber?
    rodnok01's Avatar
    Feb 2012
    NC
    6,675
    Re: Hydraulic Mount
    If it failed that quick would almost have to be a bad one, unless another mount was completely torn loose putting all the pressure on that one. Does your year have torque struts?
    Aug 2013
    30
    Re: Hydraulic Mount
    All the other mounts were changed at the same time, and are still good. I thought about that, but definitely not the case here (good idea though). What are torque struts?
    Edit: No, it doesn't have torque struts, just the hydraulic mount up front for the transverse fwd models I believe.
    Aug 2013
    30
    Re: Hydraulic Mount
    I ended up buying the GM mount on ebay, as I already tried the anchor mount. We will see what happens this time!
  11. Remove Advertisements
